Another OS suggestion
2002-10-04 by erik_magrini@Baxter.com
I noticed this last night again while working on the XL-7, something I had meant to bring up before. Can you guys group the Pattern Edit menu options in a bit more logical fashion so that similiar screens are sequential? Seems like they're kinda all over the place. For instance, to me it makes sense to do the following (IMHO): - leave Pattern Name first, that one makes sense. - put Extend Sequence Data right after the Pattern Length screen, since those two can be used together a lot. - Follow that up with Channel Assign. - Put the Scale/Offset Duration right after Scale/Offset Velocity (and before Shift Track, hint hint). - Leave Revert To Saved at the end, makes it easy to scroll to in the middle of editing and fixing bad takes. Anyway, just some idea. I think that overall it'd be good to see the Pattern setup and basic parameters screens come first, followed by all of the editing options, finally the list modes and Revert. rEalm
