MIDIMAXSport 8x8 XL7 In 3 XL7 outs 3out and 4out. Midi controller for
complete setup is on MIDI 8. All I wanna do is record an arp pattern
with cubase. But what ahhh... ). "Also, unless you want to record
the arpeggiation from the XL-7, you
> should turn off arp transmit (third screen in the arp menu)" Fixed
it =)
--- In xl7@y..., Aaron Eppolito <aarone+xl7@e...> wrote:
> While we are adding local off, this doesn't seem to be your
problem. Can you
> list the connections on your studio for both ins and outs? I need
three
> things: 1) where the output of your XL-7 goes (port #) 2) where the
input
> into the XL-7 comes from, and 3) where the output of the controller
goes.
> It should be XL-7 -> In3, Out3 -> XL-7, Controller -> In2 (or
something
> else). Also, unless you want to record the arpeggiation from the
XL-7, you
> should turn off arp transmit (third screen in the arp menu). Also,
you
> should make sure that you have soft thru (MERGE MIDI IN TO OUT, 4th
screen in
> Midi) to off for both A and B.
> -Aaron
> b0nez6969@a... wrote:
> > Ya you got it Aaron.. Thats what it is. But now what sucks. Is I
can
> > only use the keypads. I cant use my midi controller through cubase
> > with it b\c when I goto use that output. It does that Midi Loop
thing
> > your talkin about. Would you happen to know how to fix this? And
if
> > anyone happens to get a few spare minutes and are willing to help
> > me... I have ICQ at 6263627. I would completely appreciate any
help
> > of any kind reguarding this problem. So if anyone can answer this
> > question for me.... With Cubase ( sequencer) , I have my XL-7
plugged
> > in through a MIDIMAN 8x. I am using my output for my XL-7 on OUT3.
> > With thru on to gain access to my MIDI controller. But, when I
want
> > to use my MIDI controller for the preset arp patters or any arp
> > patterns of ANY type for my XL-7.It will not work. Neither will
most
> > of the touchpads. But, if I switch the OUT channel the XL-7 is
on. I
> > can use the arp patters with the touchpads. So my question is. Is
> > there a way for me. To make it so I can use my MIDI controller
using
> > OUT3 for the arp patterns. Cuz the touchpads arent my thing. Has
> > anyone ran into this problem? By the way. I dont have any problems
> > with my other equipment. Just the ARP with the MIDI controller on
> > XL-7. Please help =)
> > > Sounds like a midi loop. Make sure that any gear connected to
your
> > XL-7
> > > (usually a computer sequencer does this) is not echoing back the
> > information
> > > sent by the XL-7 back into the XL-7.
> > > -Aaron
> > > > Sorry everyone for taking up all this room. But i think what
is
> > > > happening is that MIDI notes are getting stuck when I try to
use
> > my
> > > > arp patterns. It plays one or two notes then the MIDI light
on the
> > > > machine stays lit as if something is getting stuck. Yanno. IS
it
> > > > possible that this could be a issue? I know its not my midi
gear
> > b\x
> > > > it works great with all my other equipment. Anyone have any
> > feedback?
> > > > --- In xl7@y..., b0nez6969@a... wrote:
> > > > > OK. Now , I do have a sound playing from it... But it plays
> > > > note
> > > > > quickly and then just breaks off into this messy soundin arp
> > > > patetern
> > > > > of crap. IS there something maybe wrong with my machine?
> > > > > > I got there. Thank you. But when I goto play a note..I
> > recieve no
> > > > > > sound? I know thats not suppose to happen. Could that be
due
> > to
> > > > the
> > > > > > patch?
> > > > > > --- In xl7@y..., "M2" <mmcquay@m...> wrote:
> > > > > > > What you have to do is go into the edit menu for the
> > individual
> > > > > > > preset, if it is a normal preset, when you get to the
Arp
> > > > screen,
> > > > > > the
> > > > > > > mode will be off. You will have to hit the cursor
button to
> > > > move
> > > > > > to
> > > > > > > the lower right level and select on, move the cursor
back to
> > > > the
> > > > > > > lower left side of the screen and then scroll until you
see
> > the
> > > > > > mode
> > > > > > > screen. From there select pattern mode. Then move the
> > cursor
> > > > > back
> > > > > > to
> > > > > > > the lower left and keep scrolling until you get to the
> > pattern
> > > > > > > screen. From there you can pick any of the patterns
> > > > available.
> > > > > > From
> > > > > > > the main screen the arp section should say A:P.
> > > > > > > Good Luck,
> > > > > > > M2
> > > > > > > > I just bought my XL-7 and have gone through the manual
> > about
> > > > 5
> > > > > > > times
> > > > > > > > now. Basically all I am trying to do is take a preset
and
> > use
> > > > > one
> > > > > > > of
> > > > > > > > the arp patterns that is under the ARP menu.
Everytime I
> > try
> > > > > all
> > > > > > I
> > > > > > > > get is nothing...if that. Can someone please help me
> > please.
> > > > I
> > > > > am
> > > > > > > > losing extreme patience with this. IF anyone has the
time
> > or
> > > > > care
> > > > > > > to
> > > > > > > > respond it would be greatly appreciated. Thanks
> > > > To unsubscribe from this group, send an email to:
> > > > xl7-unsubscribe@y...
> > > > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
