> You can turn off the keypads from sending midi to the out ports in the
> MIDI menu, "Keyboard Transmits MIDI". Page 114 of the manaul. Transmit
> MIDI Clock info is on the same page of the manual too.
> You can set the tracks to INT in the Pattern Edit menu, page 80 of the
> manual.
Nicely trawled, Erik... :-)
You only need to set tracks to INT if their MIDI channel(s) match
those of the slaves. I run something like 12 tracks of patterns, INT
mode, and then four empty tracks of EXT, so that I can switch between
four control channels for playing other gear or systems.
(The XL-7 rather nicely knows how to hold notes while you change
octave transpose settings; I'd better check that it can do this as you
change track selection, so as to sneak it in as a request if it
doesn't work yet...)
nick rothwell -- composition, systems, performance -- http://www.cassiel.com
