Réf. : Re: [xl7] help
2002-09-24 by Jean Kergutuil
HI OK , thanks a lot , the new OS is loaded...!! there was a problem with sysex delay too (i put it on 3000 !!!) and now all works fine... GREAT just a last question : what is the best way to download a sequence in the XL7 ??? (You have to boot while holding down enter first ??)
2002-09-24 by Will Cook
Ok this is kinda tricky.... although it shouldn't be now that you have the OS Load figured out. I just got my MP7 about 5 days ago, so I am not "quite" the expert... But luckily I am a computer tech and things of this nature I am intuitive about. Now you are gonna learn how to use E-Loader....., I have a tad bit to explain. First, you should familiarize yourself somewhat with E-Loader's menu. Open the program and browse the top menu buttons, etc. You will probably notice that there are a few things slightly more important than others... but since you have figured out how to load your new OS, everything should already be in place(designated midi port, etc.) to load patterns you've lost, screwed up, or maybe you are just experimenting.... The sound patterns/banks load almost JUST Like your OS, but you do a normal boot up as if you are ready to use the machine. No magic tricks, just press the power button to turn on your XL7/MP7. How does your XL7 interface with your PC? I assume that since you succeeded in loading the OS, whatever cable setup you used is working great. (You see I have an Audigy Platinum soundcard on my PC. It has midi ports in the front....so all I have to do is connect my midi cables to my pc DIRECTLY, and I am in!!! I know, I am a cheater...but hey ...whatever works! You simply plug a Midi cable in the MIDI OUT port on your XL7 to the MIDI IN port on the device you are communicating with (your PC/interface device, etc.) VERY IMPORTANT!! YOU ALSO HAVE TO PLUG IN a cable from your Midi Out [A or B port(*I used "A")] on your XL7 into your Midi IN port of whatever device you are connecting to(Your Pc, etc). But all of this should work fairly easy for you since you have already communicated with your PC once before to get the OS loaded... but hey, a review doesn't hurt. Ok, let's get to the pattern loading.... Eloader has a fairly simple menu, once you get slightly familiar with the program...and it will only get easier the more you understand the new OS's menu, and programming structure of EMU's software ( I think it is great). What you need is the manufacturer's CD that came with you XL7... or if you bought it off someone and they were a jerk enough not to give it to ya....you can download the patterns off EMU's website. Assuming you have the CD you find the folder on it that says MP7/XL7 patterns, and when you browse it...you will notice some titles look familiar...., they are the actual patterns preloaded inside your XL7... They do sound different on the PC when you open them up....but don't worry, once you reload them...they will have the original preloaded sound. You basically go to the bank menu on Eloader ....it basically asks you where to retrieve banks/patterns from ....using the program you browse your cd, go into the MP7/XL7 pattern folder, select which presets you want to reload (all of them if you must)...click on the add button after you select them, and then proceed to hit the download button..... P.S. The browsed items/cd contents will appear to your left....once selected and you click add, the selected files will be transferred to the right side of the split menu....these are the items that will actually load. If you did any tweaking to any preset files, I think that those will be lost, as factory defaults are restored....but hey , if we are doing this, there is a big chance that is what we actually want to do. Now sometimes in mid transmission, a download will fail sometimes after loading 20 files or so..... this is no worry, although troublesome at times, just deselect all the patterns above the failed one, keep the rest selected, and resend your download to continue. P.S. If you wiped your soundbanks out, every pattern that is blank will say " Empty Sequence" so you can easily tell on your XL7 which patterns loaded and failed, and they should always remain in sequential order, so there is no need for you to worry about organizing the actual download. Don't feel bad...I wiped out ALL my banks and had to reload everything....but now my MP7 is customized to my liking...and I have a much greater understanding of the box.. Good Luck... let me know if this was not clear..... perhaps I could give you a phone call...lol. __________________________________________________ Do you Yahoo!? New DSL Internet Access from SBC & Yahoo! http://sbc.yahoo.com
