Divide Drum Track Feature
2002-09-17 by Jeffkissinger
Don't know who reads this list but I have seen other feature
requests, so here is one of mine: pattern edit "divide drum track"
like in the rm1x or rs7000, which takes a drum track recorded all on
one track and slices/divides the drum hits across the next following
tracks based on an algorithm that distinguishes between the kinds of
notes/rhythm of the pattern.  The high hats would be on one track,
snare on another, bass, etc.
This feature allows you to quickly and fluidly record drum patterns
on one track, but later allowing you the flexibility to be able to
mute out the bass drum or whatever; also it allows you to easily
assign different presets to each drum part.
Thanks, Jeff
