Using triggers
2002-09-07 by joesapo
I've been looking to put some of the MIDI B channels to work as locations for presets that I just activate via the trigger buttons with latch enabled, but I've run into a problem. It seems that with the current XX-7 software, a preset on a channel will only change with a pattern when there is some note data for it on one of the 16 tracks. So here's my problem: I want to be able to use a different preset with my first 4 B channels so I can but pads and sfx and stuff on them and just latch them on and forget about them, not having to take up a track or one of the A channels. I have track 16 setup to control my sampler on channel 16B, so I tried putting some notes down on all B channels 1 - 4 (track 16 is MultiB). This works as far as pattern switching goes, but I can still hear the notes play, even at 1 velocity and zero length. How can I change my B channel presets along with my patterns without having to put down note data? Is there another way around this? Along the same lines, how do most people on the forum take advantage of the MIDI B channels? Thanks in advance. sapo
