Will anyone recommends Echo MIA.
Yes, No, Why...... ???
--- In xl7@y..., erik_magrini@B... wrote:
> Ok, a few things to clarify here:
> - A sound card does not necceasarily have a MIDI port on it, in
fact by
> definition it doesn't. The Sound Blaster series typically does,
but most
> 'pro' cards don't, you need to buy a separate MIDI box. I
personally
> would never recommend a sound blaster card to anyone looking to do
> anything serious musically, though there are certainly people out
there
> using them. Might want to look into the MIDIMan Midisport series,
> something like the 2x2 is only $70 tops, and a great way to get
midi into
> and out of the computer. The 1x1 is even cheaper if money is an
issue.
> - No sound card will have a USB input, that should be part of your
> motherbaord, and most computers built in the last few years have at
least
> two on the back already. All you'll need is a USB cable to hook
the XL-7
> directly up to the computer. Keep in mind though, that as of right
now,
> you can only use the USB functions to transfer Patterns from the XL-
7 to
> E-Loader and back. OS Updates and Presets must still be
transferred via
> MIDI.
> - Be sure to go to the Emu website and get the latest version of
the OS
> (ver1.31) for your XL-7, as well as the newest version of E-
Loader. Both
> contain info on how to install and use them. If you still need
help, let
> us know, we're always glad to help out. Welcome aboard too!
> rEalm
> Just picked up the XL-7 last week, and wanted to see if someone
could
> point me in the right direction of a sound card that would be ideal
for
> using the MIDI in/outs, and also the E-Loader software. I'm fairly
new to
> the gear, but seem to be picking most of the learning stages up,
and have
> just lost myself in it so far. (which is good!) It also helps that
one of
> best friends has a few pieces of gear too, from which I can learn
some
> valuable info from.
> I was looking at the Sound Blaster Audigy Platinum with the front
panel
> mumbo jumbo, however it doesn't seem to have a USB input. Does
anyone have
> any suggestions or feedback? thank you
