XX-7 live tips?
XX-7 live tips?
2002-07-31 by erik_magrini@Baxter.com
Hey guys, I've been waiting and hoping that there was going to be a new OS
release that would address the lack of Megamixing or RPS/RPPR facilities
in the XX-7 before I began using the XL-7 in a 100% live situation (and
not combined with turntables like I currently do).  However, with Summer
NAMM come and gone (the most obvious place to announce a new OS), it seems
I'm going to have to just figure out my own way around these limitations
so that I can start preparing a live set once again (one of the main
reasons I got the XL-7).  The biggest issue I have, is how to switch
patterns live, so that I can keep some continuity between them, and still
retain the flexibility to use which ever pattern fits the mood.  I could
certainly program some 'filler' patterns, but that would require a hard
and fast set list, something I want to avoid if possible.
I had originally hoped that the Beats functions on the trigger buttons
would help me out here, but in use it's less than ideal and is generally
more headaches than it's worth.  The riffs don't start on time with
whatever is playing, so even after a few months of practice, I still can't
trigger them accurately more than 50% of the time (and there's no second
chances live!).  Plus, they're just not flexible enough to use most of the
time, and they end up sounding like what they really are, someone else's
music, not mine.
So then I attempted to create my own Presets with custom arps to address
the problem, which by and large seemed to be the best solution, as long as
I stuck to simple arps.  Downsides are that it still has the issue with
trigger timing, and in order to get a full 16 triggers, you pretty much
need to limit yourself to the 16A channels for writing, the 16B channels
being reserved for your Trigger Presets.  Oh, and there's no easy way to
switch trigger Presets mid-set, as I need to save and load the set ups via
Multi's.
Next idea was to just use my Korg Er-1, and sync it to the XL-7 to add
some fills and consistent drum sounds while switching patterns.  This so
far is the easiest solution, as the two stay nicely in sync and I can
select which ever pattern in the ER-1 I want with the volume down and then
fade it in when  I need it.  Downsides are that I can only use drum sound
for the most part, and by the 5th or 6th pattern change, it does sound a
bit "samey" and dry compared to the XL-7 sound.  Oh yeah, and that adds
one more bit of kit (not a huge issue) and another wallwart to accomidate.
So, I'm looking to you guys to chime in and let me know how you address
these issues, or what you think Emu can do to improve the situation.
Obviously, with in the current hardware limitations too, so it's got to be
feasible.  I think Emu has done a great job at sorting out the bugs and
getting our boxes studio ready, now lets see (and help) them focus on the
live use aspect!
Re: [xl7] XX-7 live tips?
2002-08-01 by David Jones
My live set is pretty basic at the moment. I, too, have been pretty passive with the current understanding that there is more to come in the next os (I want my 2.0) But everything I've been doing so far has been syncing to my Korg ES-1 in SONG mode (MP in song mode too). It's quite tedious. The ES-1 isn't the most friendly live machine either, but for a drum box it's great. The only annoying thing to me about using SONG Mode, is I might as well just bring cds or dub plates to the gig. I'd rather have a WHOLE lot more control live. Currently, there's NO way for me to mix up my music. I have been toying with the idea to make multiple DUPLICATE tracks, and then just put variations. Currently, I do a lot of key changes, so there's a LOT of redundancy here. (wouldn't it be nice to change the KEY of some tracks WHILE you're playing them? - seems that the sequencer wants to STOP if you try to... can't be that far from reality)
I am enjoying the basic functionality of this unit. EMU has done great. But in my opinion, the live features have a long way to go to be crowned the king of beats. I KNOW THAT EMU CAN DO IT! This is why I anticipate any news about a new OS....
Waiting faithfully,
dB
Sent: Wednesday, July 31, 2002 10:46 AM
Subject: [xl7] XX-7 live tips?
Hey guys, I've been waiting and hoping that there was going to be a new OS release that would address the lack of Megamixing or RPS/RPPR facilities in the XX-7 before I began using the XL-7 in a 100% live situation (and not combined with turntables like I currently do). However, with Summer NAMM come and gone (the most obvious place to announce a new OS), it seems I'm going to have to just figure out my own way around these limitations so that I can start preparing a live set once again (one of the main reasons I got the XL-7). The biggest issue I have, is how to switch patterns live, so that I can keep some continuity between them, and still retain the flexibility to use which ever pattern fits the mood. I could certainly program some 'filler' patterns, but that would require a hard and fast set list, something I want to avoid if possible.
I had originally hoped that the Beats functions on the trigger buttons would help me out here, but in use it's less than ideal and is generally more headaches than it's worth. The riffs don't start on time with whatever is playing, so even after a few months of practice, I still can't trigger them accurately more than 50% of the time (and there's no second chances live!). Plus, they're just not flexible enough to use most of the time, and they end up sounding like what they really are, someone else's music, not mine.
So then I attempted to create my own Presets with custom arps to address the problem, which by and large seemed to be the best solution, as long as I stuck to simple arps. Downsides are that it still has the issue with trigger timing, and in order to get a full 16 triggers, you pretty much need to limit yourself to the 16A channels for writing, the 16B channels being reserved for your Trigger Presets. Oh, and there's no easy way to switch trigger Presets mid-set, as I need to save and load the set ups via Multi's.
Next idea was to just use my Korg Er-1, and sync it to the XL-7 to add some fills and consistent drum sounds while switching patterns. This so far is the easiest solution, as the two stay nicely in sync and I can select which ever pattern in the ER-1 I want with the volume down and then fade it in when I need it. Downsides are that I can only use drum sound for the most part, and by the 5th or 6th pattern change, it does sound a bit "samey" and dry compared to the XL-7 sound. Oh yeah, and that adds one more bit of kit (not a huge issue) and another wallwart to accomidate.
So, I'm looking to you guys to chime in and let me know how you address these issues, or what you think Emu can do to improve the situation. Obviously, with in the current hardware limitations too, so it's got to be feasible. I think Emu has done a great job at sorting out the bugs and getting our boxes studio ready, now lets see (and help) them focus on the live use aspect!
Re: XX-7 live tips?
2002-08-01 by djnorythm
I've been experimenting with a new live setup by DJing two drum
machines.  I'm putting a dj mixer between the MP-7 and the Roland D2.
Basically, the meat and potatoes of what I want to do is on the MP-7
and then I blend in the D2.  Fade out the MP-7 and then hang out on the
D2, while I reset the command station. And then start over.
Obviously, a new OS for the command stations that would include more DJ
friendly live functionality would be greatly appreciated and I agree
with Eric on his comments.
http://www.chrisshively.com/
Re: [xl7] Re: XX-7 live tips?
heh , you shoulda got a XL-7, the color would go more with the d-2 ;)
Sent: Thursday, August 01, 2002 2:13 AM
Subject: [xl7] Re: XX-7 live tips?
2002-08-01 by erik_magrini@Baxter.com
He could always paint it :)
"David Jones" <spec@...>
08/01/02 09:23 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        Re: [xl7] Re: XX-7 live tips?
Yahoo! Groups Sponsor
Click here to find your contact lenses!
2002-08-01 by Neila Eliphas Spare
Can't say that the lack of a mega-mix feature has stumbled me all that much. Granted, however that I do find such an idea nice and ever so desirable. Essientially, the most simplistic, though to a degree limiting, work around that I have found was simply to use other sequenced gear.
I will note however that I've found the capabilities of the apprigio system in the XL-7 to be most usefull for (thus far) essientially serving as sort of a replacement to Roland's RPS system (of course it works well for apprigios as well). I'll also chime in that something I'm really digging into with the XL-7 is it's ability to jump in and out of record mode while playing (just wish it could do this with grid mode as well); this definately to a degree can be used as somewhat as a replacement to Megamix (in my case, it in many ways is more desirable than megamix). Simply erase parts you no longer want and record you new lines in IN REAL TIME. Espically when in the live enviroment, I tend to like to work a lot in a improv manner, of all the gear that's graced my live p.a. setup, I have to say that the 505 by far has limited me the most in this area (megamix is a GREAT feature, but it falls way short in regards to letting you come up with something totally new on the spot). ; I've been waiting for a capable sequencer for awhile that could take a lesson from the old Roland gear and it's ability to be modify sequences to hell and back while in record mode (the 777, and Korg Etribes seemed to take in this lesson), and it's ever so nice to see that the XL-7 can carry this function out. It may not be bringing in sequences you already had made, but it's definately one way to go about brining in new sequences to the patterns your running on the fly.
However, one big issue I'm having in regard to the XL-7 (I sent a previous email to the list in regard to this, but appearently it didn't make it) comes in regard to switching the track you are working on in more of a instintaneous manner. Can't say that I like having to surf through channel buttons in order to reach a desired channel. Is there any way to go about reaching a desired channel utlilizing no more than one or two button clicks?
On another issue, I also was wondering where on earth is the USB port on the XL-7, I can't locate it at all and granted I am yet to read the manual cover to cover, I can't find any mention of it in the manual (contents or index).
And yes, yet another question, I've been searching through the manual and have yet been able to find how exactly I go about setting what exactly Mod1 and Mod2 effect. Can someone tell me how to go about doing this.
To wrap up my own personal questions in regard to this beast, I'm having some trouble with one of my mute/trigger buttons, specifically mute/trigger button 3. I often find that I have to hit it a couple times in order to have it work. I was thinking that I can probably just dig underneath the hood of this thing and do some simple realigning in order to solve the problem. rEalm, as you've been underneath the hood of this thing already, mind telling me your thoughts on where this problem may be steming from and if my idea on how to fix it might work or not.
Respects,
Aaron Nesby
Sent: Wednesday, July 31, 2002 11:46 AM
2002-08-01 by Nick Rothwell
'tis a shame, then, that the arpeggio interval stuff is broken. (See
the bug database.) This really needs to be fixed in the next OS
update.
My XL-7 isn't here right now, but: can't you use the assignment panel
in the middle to attach the data entry wheel to track/channel
selection?
It's on the back: it's a USB *client* socket, not a host socket. (USB
is stupid this way; Firewire isn't.)
I've got a bit of cruft with the track/channel up/down buttons but I'm
assuming they'll ride up with wear. Or ride down, or something.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
>>>Ditto, it's the closest thing to RPS in the XX-7's at present, as long
as you don't mind editing User arps. <<<
>>>Hold down PLAY while pressing RECORD (while the XX-7's playing).  :)
Damn those manuals!<<<
>>>Yeah, that's a good point.  Jumping to a track/channel to spur of the
momment use the Quick Edit knobs can take too long while you scroll.  I
think it would be cool to just hold down EDIT + the Track MUTE button for
that channel to select it.  Much quicker. <<<
index).
>>>I hope you're kidding.  It's on the back, and it's the connector that
doesn't look like a mains, 1/4", or RCA port :) <<<
>>>It's on the Patch Cords page for each Preset (the settings of the Quick
Edit knobs are Preset dependant).  Go to the Patch Cords page and set
Controllers "M" and "N" to control whatever parameter you want them to
control, as well as the amount. <<<
>>>It might be just pressing against the case itself, I know my data knob
wasn't soldered onto the PCB board 100% flat, so my knob was rubbing
against the case at one point every rotation.  In my case, I just pulled
the knob off and sanded down the edge of the knob and all was well (you
can't see it either).  Be careful if you open up the case, especially for
that section.  The LEDs in the XX-7 all have light pipes that trasmit the
light to the front of the case, and they ARE NOT glued on.  So if you pull
off that board to take a look, chances are a bunch of small plastic pieces
will come loose with it.  Not saying it's an impossible task, but to put
everything back together you need to use a hot glue gun or rubber cement
to hold them in place while you reassemble.  It's easy to do, just a
little bit time consuming.
So if you're up for it, take it apart and press that button out of the
case to see if it still sticks.  If it doesn't then it's probably rubbing
against the case, just sand down the inside of that button hole to make it
smoother and remove a little bit of the paint (you won't see it).  If it
does still stick, then it's a faulty button and probably needs to be
replaced,  I know you just got your XL-7, so I would just take it back and
get another one if you haven't gone over the store warrenty.  Much easier,
and you don't need to worry about messing anything up internally and
ruining your manufacturer's warrenty.<<<
selection?
>>>Yeah, but it's still not as quick a button press(es).  Plus, I need to
keep that display on the Bars and Beats setting to know where in my
pattern I am sometimes, especially live. We're just picky I guess! :) <<<
Re: XX-7 live tips?
2002-08-15 by robotchas
I was harping on this problem a while back; it's the main reason why I decided not to buy an XX-7. It's clearly intended to be used as a live sequencer (gooseneck lamp jack) but it lacks one of the most crucial features of a live sequencer, a good way to change patterns during a performance. And if you're not using the XX-7 as your main sequencer, why not get an XX-1 instead?
A program change or sysex message to select pattern numbers would at least let you switch from a PC-1600 or footswitch board (I play guitar too)...but it won't do that either (only the otherwise very limited Electribes will).
Hopefully E-mu will eventually address this with an update, but at this point I've given up and decided to try Ableton Live instead. I wish Live played back MIDI sequences as well as audio, but the degree of MIDI control is much higher than ANY of the hardware sequencers, and I can use Max to cover the must-be-MIDI stuff.
2002-08-15 by Nick Rothwell
It has a perfectly good mechanism to change patterns during a
performance: the buttons on the front panel...
I do see your point (and I use the XL-7 for live work as well,
together with Max/MSP for MIDI control). The XL-7 provides as much
MIDI control as I need (program changes and volume control in
particular), and since I use it as a control surface I don't mind
switching patterns directly as well, but if you wanted to sit the XL-7 out
of reach more automation would be nice (such as track mute control).
Certainly, more automation would be nice for sequencing: the more that
can go into the sequencer, the less that you have to fly in or
multi-pass by hand.
Ableton Live looks interesting, but I've not spent a lot of time with
it. Let us know how it turns out as a performance tool.
Re: XX-7 live tips?
2002-08-15 by heinrich22001
See my posting "Emu alive and Kicking..."
I really love my mp-7. But I find myself using the computer sequencer
way to often, I actually wanted to go away from it. Then again a
mophatt would have been enough. I really hope for some new OS-
features like real time pattern switching. I wish it had the
sequencer guts of the rm1x. I definitely would pay for a further
devellopment of the XX-7 OS.
Best regards
HEinrich
Re: XX-7 live tips?
2002-08-16 by robotchas
Hmmm? Did I miss something? I'm pretty sure last I checked the only way to select patterns was via the data wheel, but it's been several months. Unless you mean stepping up and down...I want full-on, one-touch random access.
You're probably not looking to switch patterns as vigorously as I am, but I can see why it would appeal to you as a control surface. And yeah, more track mute control would also be on my list, along with a grid editor that doesn't chase playback.
Yeah, will do...I know you're adverse to using samples (I'm familiar with some of your work), as am I, but I like the extensive MIDI control it offers.
[xl7] XX-7 / Max/MSP
2002-08-16 by just john
If anybody's whipped up Max/MSP stuff specifically for the XX-7, I'd love
to steal a copy.
I bought Max/MSP a couple years ago and haven't done very much with it at
all ...
* just-john@...  http://just-john.com/cn/rfe.shtml *
2002-08-16 by Neila Eliphas Spare
>>Actually you can change patterns via foot pedal as well.
>>Gotta say I'd like a Grid mode that simply gave one the option to have it chase playback or not to chase playback. Both modes have their own good and bad points.
Respect,
Aaron Nesby
www.twenty3.tk
Re: [xl7] XX-7 / Max/MSP
2002-08-21 by Nick Rothwell
> to steal a copy.
I've written a simple bank-transfer librarian for the presets in Max;
it does the handshaking stuff. I'd like to be able to back up patterns
as well, but E-mu have no documentation on this, so sooner or later
I'll have to reverse-engineer it.
