Index last updated: 2026-03-30 17:44 UTC
muting tracks in song mode
2001-10-08 by gary saville
Does anyone know if it is possible to record mutes into a song using realtime recording mode?
I am trying to cut tracks out shortly after they sound so you can hear the delay on the track decay.
Will I have to use an external sequenser to record this effect?
Gary
saville@...
www.mythic.com
__________________________________________________________
Get your FREE personalized e-mail at http://www.canada.com
Re: muting tracks in song mode
2001-10-10 by larremu@cs.com
Hi Gary,
Yes! You can record mute & un-mutes in song mode/realtime record.
This allows lots of possibilities, such as using only 1 pattern over
& over again, with different mute/un-mute conditions. Actually, if
you play some of the songs that came in your Command Station you will
notice this trick being put into action. Also, this is an excellent
area to record realtime knob movements instead of having them in the
pattern! So...have at it!
-ultrawoof96 (Larry)
> Gary
> saville@c...
> www.mythic.com
2001-10-12 by drk@delora.com
--- In xl7@y..., larremu@c... wrote:
> Hi Gary,
record.
over
Station you will
them in the
Not owning a XL-7 I hesitate to say this, but I do not believe this
is true and would like Emu to verify one way or another.  As this
is an important feature to me, and is not often correctly
implimented, I tried this experiment in GC just last week.  It did
not work.
What does work is that every time you step enter a pattern you
can assign it any combination of mutes.  But this is the only way
to record mutes in song mode.  Unless I missed something
(stores are not an ideal place to test things).  Again I hope I am
wrong, and hopefully Emu will clear this up!
drK
________
Re: [xl7] Re: muting tracks in song mode
2001-10-12 by gary saville
Yea, I've tryed through pattern mode and song mode, there doesn't seem to be a way to make a track trigger mid-bar, only on the downbeat of one.
I've gotten around it by triggering the track and then using the volume nob to bring the track in and out. But this can take allot of editing because if your timing isn't right on you hear the volume scoop in.
All around the sequencer could use more features, like a gate feature in grid record mode, and realtime recording should really record everything you do. Maybe future os upgrade could address it.
Sorry I don't mean to sound like a drag or anything, I love the box. but I don't think I'll be using it as my main sequencer.
Cheers
Gary.
saville@...
www.mythic.com
> > Hi Gary,
> record.
> over
> Station you will
> them in the
> not work.
> drK
> ________
