More questions
2002-07-12 by noision1
The reference to an auxilliary midi channel setting for a particular track in Pattern edit mode has me scratching my head. Is it there? Volume/Pan knobs. Is it true that in this mode the knobs are welded to channels 1A though 16A only and not more logically to to *tracks* 1 though 16? If a track in a patter is set to a B midi channel, then the corresonding knob does not much any longer but move a midi channel that you are likely not using.
