Hi all,
It seems that this group is pretty
quiet. I have a few more
questions that I hope someone can answer for
me.
>Can a whole pattern be assigned to a pad and then be triggered
>as though it was one note like a sample?
Yes, each pattern can address all of the midi
instruments at once.
>If so, do you have
>to wait until the entire pattern has played
before triggering >another?
The patterns follow the track - think of the
trigger buttons as mutes on a mixer, rather than sample triggers.
>Can different tracks in a pattern be
assigned to mute groups >so that
>you can mute an entire group by
muting only one of the mute >keys?
No, no mute assignments. Use multiple fingers.
I would really like to see group assignments - it
would make for much more powerful arrangement. Not mute groups, like the one you
specify above, but grouping like a hihats - where turning on one pattern turns
off the other's in it's group. This would let users switch melodies or drum
patterns without having to worry whether the first section is still
playing.
