Beginner tip
Beginner tip
2002-07-08 by joesapo
I just got my XL7 a little more than a week ago and i've been
struggling to understand exactly what the purpose of multisetups
are.  It didn't make sense to me that you could save a multisetup on
it's own with all the mix send outputs defined and the FX defined,
and you can save all this information in a pattern as well.  Well, it
took me a few tries mucking about with patterns before i discovered
that MIX SEND OUTPUTS defined in the global menu are only saved in
your pattern when that channel actually has some sort of data in it.
I'd been seeing my carefully layed out multisetups disappear when
changing to a factory pattern.
Also, i've got a Roland Sp-303 sampler/effects processor on midi
output B/Send2.  If you plan on using any outboard FX processing,
remember that any FX that you apply to Send2 (or send3) in the global
menu STILL GET SENT to the main outputs.  It cuts the dry signal out
of the main outs, but leaves any wet signal.  In other words, you
lose an FX send if you want a truly dry signal going out the submix
ports.  Kinda sucks, but i can deal.
If anything i hope this helps out a beginner or two like me... ;)
EMU ROCKS
sapo
