--- In xl7@y..., "Jonathan El-Bizri" <sserendipity@n...> wrote:
> Ok I see now. thank you
> hello,
> >Just acquired the xl-7. some questions regarding the arpegiator.
> >1. I have figured out how to use the mutlichannel arpegio, via
> >multiple channels with arpegio presets, but what about using five
or
> >six of the factory arpegio patterns,(the ones in the master
section,
> >the blessed 200 factory apegio patterns not presets), with presets
> >that DONT have the ARP: designation in front of them.
> >IE: pick a preset, pick a arpegio pattern put it on a
channel/track
> >combination. repeat many times until happy.
> You'll have to set an arpeggio with the preset you want to use.
> 1. Press the patch button under edit in the top right hand corner
> 2. Press the arpeggio button in pattern/trigger/edit section
> 3. Scroll until you get to the arpeggios section, and select the
arpeggio
> you want to use with the patch.
> 4. Save the patch to the user section.
> xl7-unsubscribe@y...
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
