Solid red MIDI In light indicates midi loop?
2002-06-04 by tommy_trance
Does a solid red MIDI in light from the xl7 indicate there's a midi
loop somewhere in my setup or is it normal? I think a steady blinking
red MIDI in light is how it normally should be ?
Re: [xl7] Solid red MIDI In light indicates midi loop?
2002-06-04 by Aaron Eppolito
It would do this if you are sending it MIDI clock...
A loop would imply that both lights would be lit.
-Aaron
tommy_trance wrote:
>Hi,
2002-06-04 by Nick Rothwell
...which is not necessarily wrong. Anyone using a MOTU interface with
the XL-7 will see this, since MOTU boxes always echo beat clock out to
all ports.
What interests me is that the MIDI activity lights on the XL-7
actually flicker markedly, when they should be indicating constant
beat clock and nothing else. Then again, I've found that the sequencer
timing in the XL-7 leaves something to be desired.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
  upcoming gig at cybersonica, london, june 5th  -- http://www.cybersonica.org
Re: Solid red MIDI In light indicates midi loop?
2002-06-19 by balcra
Nick, as a potential XL-7 purchaser would be interested in your
findings.  Could you elaborate pls?
-b
Re: [xl7] Re: Solid red MIDI In light indicates midi loop?
2002-06-20 by Nick Rothwell
Sure, when I've had a chance to make some timings. The XL-7 is still
sitting in a rack case awaiting unpacking after a gig...
2002-06-20 by erik_magrini@Baxter.com
Just for contrast (and in no offense to Nick and his findings), Nick is
the only one on the list with timing problems I believe.  For the vast
majority of us it's rock solid.  Again, not saying Nick is wrong or
anything, in his particuar set up there may very well be some timing
issues.
balcra <balcra@...>
06/19/02 04:55 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Solid red MIDI In light indicates midi loop?
-b
