cubase/midi problem (again and worse)
2002-05-30 by coscon23
alex, eric thanx for clarifying things... eric... i 've got a midisport 2x4 (parallel port interface)... never had any problems with it, but after today i don't know if it's broken or something. i have to say, i haven't had much experience using the mp7 in a synth module way (just using the sounds via cubase, not the sequencer). up till now i just messed with the midi parameters to get it to work. this being my "intuitive" way of working. (note; this is just a way of saying i'm not entirely understanding what i'm doing). but today i got a midi feedback loop which totally freezed the mp7 (cubase wasn't happy either). it took me several on/offs to understand it was a feedback loop and when i removed the midi-out from the mp7 everything worked okay. i can't imagine what i've been doing wrong and i think this shouldn't be possible. in my process of trying different parameters in the midi section (midimerge on/off, rechannelizing etc..) i'm sure i tried them all before and never has this kind of midi feedback occured before. anyone else had this problem? which midi parameter settings should i avoid and which should i use? or is it a cubase/midisport problem? thanx, peter.
