XL-7 import/export sequences bugs
2001-10-02 by sserendipity@newsfeeds.com
I'm at my wits end. It seems like I can't import a sequence into the xl-7 without a ton of bugs cropping up; tracks don't play, though their lights will come on, they play but are assigned to the wrong pad, apparently erasing the original pads contents, the pattern is the wrong length etc, etc Never a dull moment. There's little rhyme or reason to the changes either - there's no way to figure out what will happen the next time. I'm using logic audio to edit the sequences, and right now doing nothing more to them than editing the velocities, and removing a couple of notes. I'm at my wit's end, since writing on the XL takes 10 times as much work as using a real sequencer, but 'fixing' a pattern that has been exported is so much more work, and messes with my head. Perhaps logic is the culprit. Has anyone had any better luck with other sequencers? I'm thinking about a switch back to Cakewalk anyway, since I own an older version I could probably upgrade. (Or perhaps it's time to dust off that old copy of 3.0 instead :>) What do you guys at emu use?
