Index last updated: 2026-04-03 18:22 UTC
Touch Strip
Touch Strip
2002-05-30 by John Royle
Hi, does anybody know how to use the touch-strip to send external midi cc data? I couldn't seem to find out how to do it. I know you can patch it to many of the attribs of a preset, but i want to use it to control some of my other midi gear.
cheers,
john.
This e-mail and its attachments are intended for the above named recipient(s) only and may be confidential, legally privileged and protected by law. If you are not a named addressee or have received this transmission in error, please notify us immediately at postmaster@twowaytv.co.uk and then delete this e-mail. As Internet communications are not secure we do not accept legal responsibility for the contents of this message or responsibility for any change made to this message after the original sender sent it. Save for this legal notice, the contents or opinions contained within this e-mail are solely those of the sender and do not necessarily represent those of Two Way TV Ltd unless otherwise specifically stated.
Touch Strip
2004-07-20 by _5ht
I am a proud new owner of a PX-7.
I am playing around, checking out the sounds (fantastic), waiting for
all ROMs to arrive before I open up the box and install them.
I have a question. As I run my finger along the touch strip, nothing
seems to be happening. I do not notice any chance in sound. Do I need
to activate it or something first?
I plan on calling Emu tomorrow, but in the meantime, if someone can
point me in the right direction I would appreciate it.
Sustain for MK-6
2004-07-20 by John Schmidt
Can anyone tell me how to get sustain on the MK-6 keyboard, MO-Phatt version
of XX7/\
When I plug an unlatched keybaoard (Boss FS-5U) pedal into the foot switch
or foot pedal, I am (so far) unable to activate the sustain function.
Switching the polarity switch does not help.
Do I need a special pedal?
Any thoughts are appreciated.
Re: Sustain for MK-6
2004-07-20 by gutman75
Does the MIDI In LED blink when you press the pedal?
If not, something's wrong with your keyboard/pedal.
If it does, try different presets to see if any of them sustain (the
organs in MP-7 should).
I had a problem that some presets would sustain, while others won't.
Apparently, you have to set up a patchcord along the lines
of "FootSW1 -> KeySust" for any layer you want to sustain.
Hope this helps,
Boris.
Phatt version
> of XX7/\
switch
function.
Re: [xl7] Touch Strip
2004-07-20 by erik_magrini@Baxter.com
Make sure that the pitchbend amount in the Controllers menu is set to
something other than 0.  Should be working by default though, if you're
comfortable with it, just open up the unit and make sure that the
pitchstrip cabel is plugged into the main board fully.  If it is and it's
still not working, you may need a new one.  These are VERY easy to replace
though. it's just a sticker basically, so if you don't want to part with
your new baby to send it back to Emu, ask them to just send you the strip
and replace it yourself.
_5ht <_5ht@...>
07/19/2004 07:14 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Touch Strip
Yahoo! Groups Links
material from any computer.
For Translation:
2004-07-20 by ||||* *||||
Is it possible to replace the touch strip with a common pitchbend wheel? and
if the answer is yes, is the hold function still available?
XXX
T.
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
?????  It would take some work, if it's even possible.
"||||* *||||" <trabantmusic@...>
07/20/2004 01:30 PM
        cc:
        Subject:        Re: [xl7] Touch Strip
and
XXX
T.
Yahoo! Groups Links
For Translation:
Song loop?
2004-07-22 by zerocrossing2001
Hey,
Is there anyway to loop an entire song?  I couldn't seem to find any way to go back to the
begining of a song without stopping it.
Mark
Re: [xl7] Song loop?
2004-07-22 by erik_magrini@Baxter.com
Nope, sorry.
zerocrossing2001 <zerocrossing2001@...>
07/22/2004 09:40 AM
        cc:
        Subject:        [xl7] Song loop?
Hey,
to go back to the
Mark
Yahoo! Groups Links
For Translation:
2004-07-22 by G e r a e u s c h d i c h t e
> to go back to the
from the manual (version g), p 78:
In Song Mode
Loop Section works a little differently in Song mode
where it simply
specifies alternate start and end points. When the
song reaches the
endpoint, it stops and auto locates to the start
point. In both pattern and
song modes, RTZ still locates to the beginning of the
sequence.
hans
feindbild musik: check http://www.electrobel.be, user feindbild
http://www.etherialdawn.be
http://www.isabellableeds.com
http://www.spectre.be
-|[ G E R \ufffd U S C H D I C H T E ]|-
Gesendet von Yahoo! Mail - Jetzt mit 100MB Speicher kostenlos - Hier anmelden: http://mail.yahoo.de
2004-07-23 by erik_magrini@Baxter.com
Sorry, I'm a tard.
"G e r a e u s c h d i c h t e" <geraeuschdichte@...>
07/22/2004 03:14 PM
        cc:
        Subject:        Re: [xl7] Song loop?
> to go back to the
In Song Mode
where it simply
song reaches the
sequence.
hans
-|[ G E R Ä U S C H D I C H T E ]|-
Yahoo! Groups Links
use of, or taking of any action in reliance upon, this information by
For Translation:
2004-07-23 by G e r a e u s c h d i c h t e
--- erik_magrini@... schrieb: > Sorry, I'm a
tard.
> rEalm
:o) no need to exaggerate. you have proven your widom
many times on this list (and others) already.
Ok, then I'll say I'm a Song Mode tard :)
> Sorry, I'm a tard.
> rEalm
Yahoo! Groups Links
For Translation:
--- erik_magrini@... schrieb: > Ok, then I'll
> rEalm
oh, that i am as well. was rereading the manual and
coincidentally i had read exactly that paragraph in
the manual a few minutes before i read the question
;o)
hans
2004-07-23 by Aaron Eppolito
Actually, rEalm, you're right (about song mode, not about being a
tard).  There is no way to loop song mode.  The temporary bar region
thing only stops and automatically returns to zero, it does not loop
like pattern mode.  Song mode was hard enough without having to make it
loop seamlessly like pattern mode (where we guarantee ~2ms accuracy on
the loop).
-Aaron
> > rEalm
> ;o)
Do you Yahoo!?
Vote for the stars of Yahoo!'s next ad campaign!
http://advision.webevents.yahoo.com/yahoo/votelifeengine/
Re: Song loop?
2004-07-27 by zerocrossing2001
Damn.  Pretty glaring ommission, no?  Put it on a wish list, I guess.
Mark
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> Nope, sorry.
> rEalm
