The day I Stop asking dumb questions
2002-05-24 by David Jones
2002-05-24 by erik_magrini@Baxter.com
Hold down PLAY while perssing REC. :)
(is this where I'm supopsed to say RTFM?) j/k
"David Jones" <spec@...>
05/24/02 08:44 AM
Please respond to xl7
cc: Subject: [xl7] The day I Stop asking dumb questions Is it possible to go into grid record mode while the sequencer is playing? The on the fly capabilities of grid are amazing. To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2002-05-24 by Aaron Eppolito
David Jones wrote: > Is it possible to go into grid record mode while the sequencer is > playing? The on the fly capabilities of grid are amazing. Not a dumb question. In fact I wanted to do this too, so I put in a button combination to do it. While playing, hold play and push record. -Aaron stopped [push play] => play play [push rec] => RT record RT record [push rec] => play play [press play + rec] => grid record grid record [press rec] => play
----- Original Message -----From: Aaron EppolitoSent: Friday, May 24, 2002 10:02 AMSubject: Re: [xl7] The day I Stop asking dumb questionsDavid Jones wrote:
-Aaron
David Jones wrote: > *Gripe* it stops the track when I hit play again. :( - Is there a > reason for this? I jammed out hardcore lastnight and the MP > performed! Now if I could only switch off that Audition button - I > kept accidently hitting it while hitting the track buttons. :/ Yes, there's a reason for this. It's so you can hang out at a particular bar to do editing without it flying by. I assume that you want to come back out of grid record while still playing. Press rec instead (punch-out). grid record [push rec] => play grid record [push play] => grid paused grid paused [push play] => grid record grid paused [push rec] => stopped Oh, and the audition thing? You could always pop out the button... I've done that for the soft-power button on my machine. -Aaron
----- Original Message -----From: Aaron EppolitoSent: Friday, May 24, 2002 10:19 AMSubject: Re: [xl7] The day I Stop asking dumb questionsDavid Jones wrote:
*Gripe* it stops the track when I hit play again. :( - Is there a reason for this? I jammed out hardcore lastnight and the MP performed! Now if I could only switch off that Audition button - I kept accidently hitting it while hitting the track buttons. :/
grid record [push rec] ;=> play
-Aaron
2002-05-28 by tommy_trance
from the FAQ located in the files section. Basically, set your desire tracks' master fx to have a send 0. -How do I use the effects in the Command Station, I don't understand the sends? First of all, there are two effects available in the Command Stations at all times, regardless of whether you're only playing a single Preset, or a Pattern with 16 Tracks playing at once. You can use the effects in two main ways, each selected from the Global menu. The first way is where the active Preset you're playing controls what the effects will be, and therefore all the effects settings are stored with that Preset. This way works best if you're only playing a single Preset at a time, from a master keyboard in a live situation for instance. The second way of using the effects is in Master Effects mode. In this case, all Presets share the same two effects, and the effects and all their settings are saved as part of each Pattern. However being able to only turn the effects on or off for each part is not very flexible, so Emu uses effect Sends to increase your options with only two effects. Just like there are only two effects for the entire Command Station, there are only four Sends for the entire unit as well. The send amounts for each effect are freely assignable in the Global menu. Here's an example of how they work. For instance, say your first effect is a reverb, and your second is a delay. You can specify how much reverb you want to be applied to Send 1, as well as how much Delay you want to be applied to Send 1. Say you set your reverb amount to 5% on Send 1, and your delay amount to 27% on Send 1. In this configuration, any Track you route to Send 1, will have about 5% reverb on it, and then it gets about 27% of the delay effect added to it. Simple huh? If you only wanted reverb for instance, you would just set the delay amount for that Send to 0%, and now all Tracks routed to Send 1 will only have reverb applied. BTW, you can assign more than one Track to a Send, and you've got 4 Sends to use for your whole Pattern, giving you lots of ways to use only those two effects processors. --- In xl7@y..., "David Jones" <spec@s...> wrote: > Next question. I'm assuming that there is realy no way to get a completely dry out if you're using both fx processors as well as both sub outs for outboard fx/signalprocessors. . . Am I wrong? > ----- Original Message ----- > From: Aaron Eppolito > To: xl7@y... > Sent: Friday, May 24, 2002 10:19 AM > Subject: Re: [xl7] The day I Stop asking dumb questions > > > David Jones wrote: > > *Gripe* it stops the track when I hit play again. :( - Is there a reason for this? I jammed out hardcore lastnight and the MP performed! Now if I could only switch off that Audition button - I kept accidently hitting it while hitting the track buttons. :/ > > Yes, there's a reason for this. It's so you can hang out at a particular bar to do editing without it flying by. I assume that you want to come back out of grid record while still playing. Press rec instead (punch-out). > > grid record [push rec] => play > grid record [push play] => grid paused > grid paused [push play] => grid record > grid paused [push rec] => stopped > > Oh, and the audition thing? You could always pop out the button... I've done that for the soft-power button on my machine. > > -Aaron > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@y... > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
