Halo keyboard & ZR ROM
2002-05-13 by uwodsi
Hey, I am looking at purchasing one of the new Halo keyboards which has an updated Sounds-of-the-ZR ROM, and sent a message to both EMU and William Coakley regarding the piano presets which had programming errors in the ZR ROM version. My question and Mr Coakley's response are pasted below. Would someone from EMU please reply as I have had no response from a direct email. Thanks Peter pkirkup@... I am looking at purchasing one of the new EMU-Ensoniq keyboards called Halo. It has the same soundset used in the Sounds of the ZR ROM plus an extra bank of presets, and, presumably, a different ROM id number. At www.williamcoakley.com there are 5 presets to be downloaded that use the Coakley's Perfect Piano samples in the ROM, apparently correcting some crossfading that wasn't set up real well in the ROM presets. I am suspecting that if I try and download the presets into the Halo, because the ROM id is (presumably) different, it won't work. Can somebody let me know if this is the case, and if the presets at www.williamcoakley.com will be made available in a version for the Halo, with the id numbers changed, as I am going to purchase the Halo more or less on the grounds that it has Coakley's perfect piano in it. Mr Coakely's response: I brought this up to Emu folks at the trade show in January. They were going to ship me a Halo for tweeking but stuff like that usually never happens when you think... I still haven't heard from anyone over there. But all that aside, they were supposed to have downloaded my corrections and put them into the unit. I cannot verify if this has actually been done or not. And since I still don't have a unit to check, I can't vouch for anything at the moment.
