workarround for track switching without cutting external notes
2002-05-09 by Alexander Rüsberg
i´ve found a way to switch tracks without cutting notes on tracks that are set to external.
just use the channel / track edit button and data wheel, or switch to preset and then use the track+/- keys. this is very cool if you use built-in arpeggiators on your external gear.
sadly this only works for external tracks only. the internal arpeggiators will be cutt anyway.
i still hope that emu manages to fix this on one of the comming os releases.
alexander
