glide
2002-05-05 by mikexl7
I have tried saving the preset that i am using with the glide engaged like 3 times now and it wont rember that the glide it engaged. Any one have any idea of what is happening here? peace Mike
2002-05-06 by Aaron Eppolito
The glide button status doesn't get saved with the preset. Rather, it's initial state is derived from the preset. If any one (at least) layer has a glide amount other than 0.000 sec/oct, the light will come on, and pressing it will remove all glide. If all layers are 0.000 sec/oct, the light will be off (even if there are patchcords adding glide!) and pressing the button will add ~0.177 sec/oct glide amount. Personally, for the presets that I want the light to come on, I tweak one layer to be 0.002 sec/oct, set the rest to 0.000, then I hook up MidiN to glide amount at 100% for all layers that I want glide. This way, I have a knob that controlls glide amount, and a switch to turn it on and off. -Aaron mikexl7 wrote:
> I have tried saving the preset that i am using with the glide > engaged like 3 times now and it wont rember that the glide it > engaged. > > Any one have any idea of what is happening here? > > peace > > Mike
2002-05-06 by adamhertzano
Make sure there is a glide value of at least 1. Think that should work since the glide feature changes nothing unless u set it to a minimal Value! \Hope this helps Adam --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote:
2002-05-07 by divisionstreet13
try saving in emty sequence the preset and then use the glide and save ----- Original Message -----
From: "adamhertzano" <adamhertzano@...> To: <xl7@yahoogroups.com> Sent: Monday, May 06, 2002 9:57 AM Subject: [xl7] Re: glide > Make sure there is a glide value of at least 1. > > Think that should work since the glide feature changes nothing unless > u set it to a minimal Value! > > \Hope this helps > > Adam > > > > > > --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote: > > I have tried saving the preset that i am using with the glide > > engaged like 3 times now and it wont rember that the glide it > > engaged. > > > > Any one have any idea of what is happening here? > > > > peace > > > > Mike > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2002-05-07 by mikexl7
Thanks Aaron that fixes that. --- In xl7@y..., Aaron Eppolito <aarone+xl7@e...> wrote: > The glide button status doesn't get saved with the preset. Rather, it's > initial state is derived from the preset. > > If any one (at least) layer has a glide amount other than 0.000 sec/oct, the > light will come on, and pressing it will remove all glide. > > If all layers are 0.000 sec/oct, the light will be off (even if there are > patchcords adding glide!) and pressing the button will add ~0.177 sec/oct > glide amount. > > Personally, for the presets that I want the light to come on, I tweak one > layer to be 0.002 sec/oct, set the rest to 0.000, then I hook up MidiN to > glide amount at 100% for all layers that I want glide. This way, I have a > knob that controlls glide amount, and a switch to turn it on and off.
> > -Aaron > > > mikexl7 wrote: > > > I have tried saving the preset that i am using with the glide > > engaged like 3 times now and it wont rember that the glide it > > engaged. > > > > Any one have any idea of what is happening here? > > > > peace > > > > Mike
Yes the box is worth it. This box had it's issues in the start but it is a very stable unit now. I love my xl7 and cant think of anything I would replace it with at any price let alone the modist one that is. Pattern swtiching is now rock solid. You can save and arange you patterns with your computer. It is small. The key pad is amasing. the sounds are great. The outputs are more flexable than any gear i have ever heard of. It is built like a tank not like a toy. I could go on and on about this unit, bottom line if you want a killer unit buy a XL7. Peace Mike G.
2002-05-07 by drj0
Ok, guys. Thats what i thought. It's funny how things are. If something is great, you never hear about it. if there's somthing wrong with it you hear a LOT about it. I think most of the negitive posts that I see refer to an older OS. I have not played with this unit yet. Nor will I likely be able to before I buy it. But that should be ok. I plan to replace everything in my setup with the XL-7 and the RS-7000 .... so far that seems like a very good idea. I'm sick of hauling racks of gear and want to narrow it down to one rack and one suitcase, 5 minute setup time, and rock the floor... Also, I encorporate Turntablism, scratching, juggling, and cutting into my sets. It's only imparitive that I have somthing that's compact and can easily fit above the decks. The sound of Emu Products is AMAZING. I can't wait to get one of these things and load it with the XL, World, and err... any chance i can get 8 slots ;) - And finally somthing that can replace my old alesis sequencers. ok, you got me excited again. I was a bit worried.... however... I haven't heard much of the jungle/Drum&bass community saying much about this unit... anyone? --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote:
> Yes the box is worth it. > > This box had it's issues in the start but it is a very stable unit > now. I love my xl7 and cant think of anything I would replace it > with at any price let alone the modist one that is. > > Pattern swtiching is now rock solid. > You can save and arange you patterns with your computer. > It is small. > The key pad is amasing. > the sounds are great. > The outputs are more flexable than any gear i have ever heard of. > It is built like a tank not like a toy. > I could go on and on about this unit, bottom line if you want a > killer unit buy a XL7. > > Peace > > Mike G.
2002-05-07 by drj0
Are you sayint that they're planning on putting a SOFT sampler IN the xx7? Or are you speaking of Emulator 5 or a simular product? --- In xl7@y..., "divisionstreet13" <divisionstreet13@c...> wrote: > I agree it is one of the best machines I have worked with, once the soft > sampler is integrated, it in my book is just as if not mere powerful than > the mpc2000, the filters in the xx-7 alone is $1000. > ----- Original Message ----- > From: "drj0" <drj0@y...> > To: <xl7@y...> > Sent: Tuesday, May 07, 2002 8:01 AM > Subject: [xl7] Re: IS IT WORTH IT?! > > > > Ok, guys. Thats what i thought. It's funny how things are. If > > something is great, you never hear about it. if there's somthing > > wrong with it you hear a LOT about it. I think most of the > > negitive posts that I see refer to an older OS. > > > > I have not played with this unit yet. Nor will I likely be able to > > before I buy it. But that should be ok. I plan to replace > > everything in my setup with the XL-7 and the RS-7000 .... so far > > that seems like a very good idea. I'm sick of hauling racks of gear > > and want to narrow it down to one rack and one suitcase, 5 minute > > setup time, and rock the floor... Also, I encorporate Turntablism, > > scratching, juggling, and cutting into my sets. It's only > > imparitive that I have somthing that's compact and can easily fit > > above the decks. > > > > The sound of Emu Products is AMAZING. I can't wait to get one of > > these things and load it with the XL, World, and err... any chance > > i can get 8 slots ;) - And finally somthing that can replace my old > > alesis sequencers. > > > > ok, you got me excited again. I was a bit worried.... however... > > > > I haven't heard much of the jungle/Drum&bass community saying much > > about this unit... anyone? > > > > --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote: > > > Yes the box is worth it. > > > > > > This box had it's issues in the start but it is a very stable unit > > > now. I love my xl7 and cant think of anything I would replace it > > > with at any price let alone the modist one that is. > > > > > > Pattern swtiching is now rock solid. > > > You can save and arange you patterns with your computer. > > > It is small. > > > The key pad is amasing. > > > the sounds are great. > > > The outputs are more flexable than any gear i have ever heard of. > > > It is built like a tank not like a toy. > > > I could go on and on about this unit, bottom line if you want a > > > killer unit buy a XL7. > > > > > > Peace > > > > > > Mike G. > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@y... > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > >
I agree it is one of the best machines I have worked with, once the soft sampler is integrated, it in my book is just as if not mere powerful than the mpc2000, the filters in the xx-7 alone is $1000. ----- Original Message -----
From: "drj0" <drj0@...> To: <xl7@yahoogroups.com> Sent: Tuesday, May 07, 2002 8:01 AM Subject: [xl7] Re: IS IT WORTH IT?! > Ok, guys. Thats what i thought. It's funny how things are. If > something is great, you never hear about it. if there's somthing > wrong with it you hear a LOT about it. I think most of the > negitive posts that I see refer to an older OS. > > I have not played with this unit yet. Nor will I likely be able to > before I buy it. But that should be ok. I plan to replace > everything in my setup with the XL-7 and the RS-7000 .... so far > that seems like a very good idea. I'm sick of hauling racks of gear > and want to narrow it down to one rack and one suitcase, 5 minute > setup time, and rock the floor... Also, I encorporate Turntablism, > scratching, juggling, and cutting into my sets. It's only > imparitive that I have somthing that's compact and can easily fit > above the decks. > > The sound of Emu Products is AMAZING. I can't wait to get one of > these things and load it with the XL, World, and err... any chance > i can get 8 slots ;) - And finally somthing that can replace my old > alesis sequencers. > > ok, you got me excited again. I was a bit worried.... however... > > I haven't heard much of the jungle/Drum&bass community saying much > about this unit... anyone? > > --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote: > > Yes the box is worth it. > > > > This box had it's issues in the start but it is a very stable unit > > now. I love my xl7 and cant think of anything I would replace it > > with at any price let alone the modist one that is. > > > > Pattern swtiching is now rock solid. > > You can save and arange you patterns with your computer. > > It is small. > > The key pad is amasing. > > the sounds are great. > > The outputs are more flexable than any gear i have ever heard of. > > It is built like a tank not like a toy. > > I could go on and on about this unit, bottom line if you want a > > killer unit buy a XL7. > > > > Peace > > > > Mike G. > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2002-05-07 by erik_magrini@Baxter.com
I plan to replace everything in my setup with the XL-7 and the RS-7000 I haven't heard much of the jungle/Drum&bass community saying much about this unit... anyone? >>>I write nu skool breaks (DnB too once in awhile), close enough! The Basslines in this thing are wicked, they'll be screaming for the rewind (err, restart)! <<<
I ain't saying anything. ;)
drj0 <drj0@...>
05/07/02 08:35 AM
Please respond to xl7
cc: Subject: [xl7] Re: IS IT WORTH IT?! Are you sayint that they're planning on putting a SOFT sampler IN the xx7? Or are you speaking of Emulator 5 or a simular product? --- In xl7@y..., "divisionstreet13" <divisionstreet13@c...> wrote: > I agree it is one of the best machines I have worked with, once the soft > sampler is integrated, it in my book is just as if not mere powerful than > the mpc2000, the filters in the xx-7 alone is $1000. > ----- Original Message ----- > From: "drj0" <drj0@y...> > To: <xl7@y...> > Sent: Tuesday, May 07, 2002 8:01 AM > Subject: [xl7] Re: IS IT WORTH IT?! > > > > Ok, guys. Thats what i thought. It's funny how things are. If > > something is great, you never hear about it. if there's somthing > > wrong with it you hear a LOT about it. I think most of the > > negitive posts that I see refer to an older OS. > > > > I have not played with this unit yet. Nor will I likely be able to > > before I buy it. But that should be ok. I plan to replace > > everything in my setup with the XL-7 and the RS-7000 .... so far > > that seems like a very good idea. I'm sick of hauling racks of gear > > and want to narrow it down to one rack and one suitcase, 5 minute > > setup time, and rock the floor... Also, I encorporate Turntablism, > > scratching, juggling, and cutting into my sets. It's only > > imparitive that I have somthing that's compact and can easily fit > > above the decks. > > > > The sound of Emu Products is AMAZING. I can't wait to get one of > > these things and load it with the XL, World, and err... any chance > > i can get 8 slots ;) - And finally somthing that can replace my old > > alesis sequencers. > > > > ok, you got me excited again. I was a bit worried.... however... > > > > I haven't heard much of the jungle/Drum&bass community saying much > > about this unit... anyone? > > > > --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote: > > > Yes the box is worth it. > > > > > > This box had it's issues in the start but it is a very stable unit > > > now. I love my xl7 and cant think of anything I would replace it > > > with at any price let alone the modist one that is. > > > > > > Pattern swtiching is now rock solid. > > > You can save and arange you patterns with your computer. > > > It is small. > > > The key pad is amasing. > > > the sounds are great. > > > The outputs are more flexable than any gear i have ever heard of. > > > It is built like a tank not like a toy. > > > I could go on and on about this unit, bottom line if you want a > > > killer unit buy a XL7. > > > > > > Peace > > > > > > Mike G. > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@y... > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Oops, that was supposed to say, "what are you going to be using the RS7000 for too?" rEalm I plan to replace everything in my setup with the XL-7 and the RS-7000 I haven't heard much of the jungle/Drum&bass community saying much about this unit... anyone? >>>I write nu skool breaks (DnB too once in awhile), close enough! The Basslines in this thing are wicked, they'll be screaming for the rewind (err, restart)! <<< Yahoo! Groups Sponsor ADVERTISEMENT To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2002-05-07 by payntaraspen
I would think news of possible additions like the soft sampler would help to boost sales... -payntar --- In xl7@y..., erik_magrini@B... wrote: > I ain't saying anything. ;) > > rEalm > > > > > > drj0 <drj0@y...> > 05/07/02 08:35 AM > Please respond to xl7 > > > To: xl7@y... > cc: > Subject: [xl7] Re: IS IT WORTH IT?! > > > Are you sayint that they're planning on putting a SOFT sampler IN > the xx7? Or are you speaking of Emulator 5 or a simular product? > > --- In xl7@y..., "divisionstreet13" <divisionstreet13@c...> wrote: > > I agree it is one of the best machines I have worked with, once > the soft > > sampler is integrated, it in my book is just as if not mere > powerful than > > the mpc2000, the filters in the xx-7 alone is $1000. > > ----- Original Message ----- > > From: "drj0" <drj0@y...> > > To: <xl7@y...> > > Sent: Tuesday, May 07, 2002 8:01 AM > > Subject: [xl7] Re: IS IT WORTH IT?! > > > > > > > Ok, guys. Thats what i thought. It's funny how things are. If > > > something is great, you never hear about it. if there's somthing > > > wrong with it you hear a LOT about it. I think most of the > > > negitive posts that I see refer to an older OS. > > > > > > I have not played with this unit yet. Nor will I likely be able > to > > > before I buy it. But that should be ok. I plan to replace > > > everything in my setup with the XL-7 and the RS-7000 .... so far > > > that seems like a very good idea. I'm sick of hauling racks of > gear > > > and want to narrow it down to one rack and one suitcase, 5 minute > > > setup time, and rock the floor... Also, I encorporate > Turntablism, > > > scratching, juggling, and cutting into my sets. It's only > > > imparitive that I have somthing that's compact and can easily fit > > > above the decks. > > > > > > The sound of Emu Products is AMAZING. I can't wait to get one of > > > these things and load it with the XL, World, and err... any > chance > > > i can get 8 slots ;) - And finally somthing that can replace my > old > > > alesis sequencers. > > > > > > ok, you got me excited again. I was a bit worried.... however... > > > > > > I haven't heard much of the jungle/Drum&bass community saying > much > > > about this unit... anyone? > > > > > > --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote: > > > > Yes the box is worth it. > > > > > > > > This box had it's issues in the start but it is a very stable > unit > > > > now. I love my xl7 and cant think of anything I would replace > it > > > > with at any price let alone the modist one that is. > > > > > > > > Pattern swtiching is now rock solid. > > > > You can save and arange you patterns with your computer. > > > > It is small. > > > > The key pad is amasing. > > > > the sounds are great. > > > > The outputs are more flexable than any gear i have ever heard > of. > > > > It is built like a tank not like a toy. > > > > I could go on and on about this unit, bottom line if you want > a > > > > killer unit buy a XL7. > > > > > > > > Peace > > > > > > > > Mike G. > > > > > > > > > > > > To unsubscribe from this group, send an email to: > > > xl7-unsubscribe@y... > > > > > > > > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > > > > > > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@y... > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2002-05-07 by John Royle
Sent: 07 May 2002 16:13
Subject: Re: [xl7] Re: IS IT WORTH IT?!
I would think so too.
-payntar
This e-mail and its attachments are intended for the above named recipient only and may be confidential, legally privileged and protected by law. If you are not the named addressee, you are not authorised to retain, read, copy or disseminate this message or any part of it. If you receive this transmission in error, please notify us immediately at postmaster@... and then delete this e-mail.
As Internet communications are not secure we do not accept legal responsibility for the contents of this message or responsibility for any change made to this message after the original sender sent it. Save for this legal notice, the contents or opinions contained within this e-mail are solely those of the sender and do not necessarily represent those of Two Way TV Ltd unless otherwise specifically stated. Although we do carry out extensive virus checking, we advise you to carry out your own before opening any attachment, as we cannot accept liability for any damage sustained as a result of any software viruses.
2002-05-07 by drj0
Bahahaha. which one do you have? The MP or the XL? --- In xl7@y..., erik_magrini@B... wrote: > I plan to replace everything in my setup with the XL-7 and the RS- 7000 > > I haven't heard much of the jungle/Drum&bass community saying much about > this unit... anyone? > > >>>I write nu skool breaks (DnB too once in awhile), close enough! The > Basslines in this thing are wicked, they'll be screaming for the rewind > (err, restart)! <<<
2002-05-07 by drj0
STOP for a moment :) This is how rumors get started. However, I sent a lengthy email to ensoniq with many questions. Their answer to many of them? Not *YET*.... Does this mean we'll have a sequencer that supports different lengths for each TRACK? (16 here, 8 there (looped 2ice)) maybe... but it seems a bit of a stretch... --- In xl7@y..., "payntaraspen" <payntar@h...> wrote: > I would think news of possible additions like the soft sampler would > help to boost sales... > -payntar > > --- In xl7@y..., erik_magrini@B... wrote: > > I ain't saying anything. ;) > > > > rEalm > > > > > > > > > > > > drj0 <drj0@y...> > > 05/07/02 08:35 AM > > Please respond to xl7 > > > > > > To: xl7@y... > > cc: > > Subject: [xl7] Re: IS IT WORTH IT?! > > > > > > Are you sayint that they're planning on putting a SOFT sampler IN > > the xx7? Or are you speaking of Emulator 5 or a simular product? > > > > --- In xl7@y..., "divisionstreet13" <divisionstreet13@c...> wrote: > > > I agree it is one of the best machines I have worked with, once > > the soft > > > sampler is integrated, it in my book is just as if not mere > > powerful than > > > the mpc2000, the filters in the xx-7 alone is $1000. > > > ----- Original Message ----- > > > From: "drj0" <drj0@y...> > > > To: <xl7@y...> > > > Sent: Tuesday, May 07, 2002 8:01 AM > > > Subject: [xl7] Re: IS IT WORTH IT?! > > > > > > > > > > Ok, guys. Thats what i thought. It's funny how things are. If > > > > something is great, you never hear about it. if there's > somthing > > > > wrong with it you hear a LOT about it. I think most of the > > > > negitive posts that I see refer to an older OS. > > > > > > > > I have not played with this unit yet. Nor will I likely be > able > > to > > > > before I buy it. But that should be ok. I plan to replace > > > > everything in my setup with the XL-7 and the RS-7000 .... so far > > > > that seems like a very good idea. I'm sick of hauling racks of > > gear > > > > and want to narrow it down to one rack and one suitcase, 5 > minute > > > > setup time, and rock the floor... Also, I encorporate > > Turntablism, > > > > scratching, juggling, and cutting into my sets. It's only > > > > imparitive that I have somthing that's compact and can easily > fit > > > > above the decks. > > > > > > > > The sound of Emu Products is AMAZING. I can't wait to get one > of > > > > these things and load it with the XL, World, and err... any > > chance > > > > i can get 8 slots ;) - And finally somthing that can replace my > > old > > > > alesis sequencers. > > > > > > > > ok, you got me excited again. I was a bit worried.... > however... > > > > > > > > I haven't heard much of the jungle/Drum&bass community saying > > much > > > > about this unit... anyone? > > > > > > > > --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote: > > > > > Yes the box is worth it. > > > > > > > > > > This box had it's issues in the start but it is a very stable > > unit > > > > > now. I love my xl7 and cant think of anything I would > replace > > it > > > > > with at any price let alone the modist one that is. > > > > > > > > > > Pattern swtiching is now rock solid. > > > > > You can save and arange you patterns with your computer. > > > > > It is small. > > > > > The key pad is amasing. > > > > > the sounds are great. > > > > > The outputs are more flexable than any gear i have ever heard
> > of. > > > > > It is built like a tank not like a toy. > > > > > I could go on and on about this unit, bottom line if you > want > > a > > > > > killer unit buy a XL7. > > > > > > > > > > Peace > > > > > > > > > > Mike G. > > > > > > > > > > > > > > > > To unsubscribe from this group, send an email to: > > > > xl7-unsubscribe@y... > > > > > > > > > > > > > > > > Your use of Yahoo! Groups is subject to > > http://docs.yahoo.com/info/terms/ > > > > > > > > > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@y... > > > > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/
2002-05-07 by drj0
Bottom line is that I need a sampler as well. I need somthing with a decent sequencer in it. The Korg ES-1 doesn't cut it either. I'm not goin fisher price if you know what i mean. Why, what do you suggest? --- In xl7@y..., erik_magrini@B... wrote: > Oops, that was supposed to say, "what are you going to be using the RS7000 > for too?" > > rEalm > > > > I plan to replace everything in my setup with the XL-7 and the RS- 7000 > > I haven't heard much of the jungle/Drum&bass community saying much about > this unit... anyone? > > >>>I write nu skool breaks (DnB too once in awhile), close enough! The > Basslines in this thing are wicked, they'll be screaming for the rewind > (err, restart)! <<< > > > > > > Yahoo! Groups Sponsor > > ADVERTISEMENT > > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@y... > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
XL-7
drj0 <drj0@...>
05/07/02 11:12 AM
cc: Subject: [xl7] Re: IS IT WORTH IT?! Bahahaha. which one do you have? The MP or the XL? --- In xl7@y..., erik_magrini@B... wrote: > I plan to replace everything in my setup with the XL-7 and the RS- 7000 > > I haven't heard much of the jungle/Drum&bass community saying much about > this unit... anyone? > > >>>I write nu skool breaks (DnB too once in awhile), close enough! The > Basslines in this thing are wicked, they'll be screaming for the rewind > (err, restart)! <<< To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2002-05-07 by Andre Lewis
Don't get rid of your ES-1, for DNB you will definately want it for beats. I re-bought an ES-1 to work with the XL-7. Also use it for drum sequencing.
-----Original Message----- From: drj0 [mailto:drj0@...] Sent: Tuesday, May 07, 2002 6:02 AM To: xl7@yahoogroups.com Subject: [xl7] Re: IS IT WORTH IT?! Ok, guys. Thats what i thought. It's funny how things are. If something is great, you never hear about it. if there's somthing wrong with it you hear a LOT about it. I think most of the negitive posts that I see refer to an older OS. I have not played with this unit yet. Nor will I likely be able to before I buy it. But that should be ok. I plan to replace everything in my setup with the XL-7 and the RS-7000 .... so far that seems like a very good idea. I'm sick of hauling racks of gear and want to narrow it down to one rack and one suitcase, 5 minute setup time, and rock the floor... Also, I encorporate Turntablism, scratching, juggling, and cutting into my sets. It's only imparitive that I have somthing that's compact and can easily fit above the decks. The sound of Emu Products is AMAZING. I can't wait to get one of these things and load it with the XL, World, and err... any chance i can get 8 slots ;) - And finally somthing that can replace my old alesis sequencers. ok, you got me excited again. I was a bit worried.... however... I haven't heard much of the jungle/Drum&bass community saying much about this unit... anyone? --- In xl7@y..., "mikexl7" <mikexl7@y...> wrote: > Yes the box is worth it. > > This box had it's issues in the start but it is a very stable unit > now. I love my xl7 and cant think of anything I would replace it > with at any price let alone the modist one that is. > > Pattern swtiching is now rock solid. > You can save and arange you patterns with your computer. > It is small. > The key pad is amasing. > the sounds are great. > The outputs are more flexable than any gear i have ever heard of. > It is built like a tank not like a toy. > I could go on and on about this unit, bottom line if you want a > killer unit buy a XL7. > > Peace > > Mike G. To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
If you're just triggering phrases, I'd say sp808 or SU700. The RS7000 is
really just an SU700 with the RM1x sound engine thrown in, and that sound
engine isn't anywhere close to what you're getting with the XX-7 (ie, it
sucks), so why pay for it? I had an sp808, and as long as you don't need
more than 4 samples playing at once I'd highly recommend it. You can get
a great effects in there, and back up to Zip is really nice too.
drj0 <drj0@...>
05/07/02 11:18 AM
cc: Subject: [xl7] Re: IS IT WORTH IT?! Bottom line is that I need a sampler as well. I need somthing with a decent sequencer in it. The Korg ES-1 doesn't cut it either. I'm not goin fisher price if you know what i mean. Why, what do you suggest? --- In xl7@y..., erik_magrini@B... wrote: > Oops, that was supposed to say, "what are you going to be using the RS7000 > for too?" > > rEalm > > > > I plan to replace everything in my setup with the XL-7 and the RS- 7000 > > I haven't heard much of the jungle/Drum&bass community saying much about > this unit... anyone? > > >>>I write nu skool breaks (DnB too once in awhile), close enough! The > Basslines in this thing are wicked, they'll be screaming for the rewind > (err, restart)! <<< > > > > > > Yahoo! Groups Sponsor > > ADVERTISEMENT > > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@y... > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Sent: Tuesday, May 07, 2002 9:31 AM
If you're just triggering phrases, I'd say sp808 or SU700. The RS7000 is really just an SU700 with the RM1x sound engine thrown in, and that sound engine isn't anywhere close to what you're getting with the XX-7 (ie, it sucks), so why pay for it? I had an sp808, and as long as you don't need more than 4 samples playing at once I'd highly recommend it. You can get a great effects in there, and back up to Zip is really nice too.
drj005/07/02 11:18 AM
cc:
the RS7000
> for too?"
> rEalm
7000
about
enough! The
rewind
> (err, restart)! <<<
> ADVERTISEMENT
Service.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA/Ey.GAA/pWZylB/TM
xl7-unsubscribe@...m
MP-7 --- In xl7@y..., "drj0" <drj0@y...> wrote: > Bahahaha. > > which one do you have? The MP or the XL? > > > --- In xl7@y..., erik_magrini@B... wrote: > > I plan to replace everything in my setup with the XL-7 and the RS- > 7000 > > > > I haven't heard much of the jungle/Drum&bass community saying much
> about > > this unit... anyone? > > > > >>>I write nu skool breaks (DnB too once in awhile), close > enough! The > > Basslines in this thing are wicked, they'll be screaming for the > rewind > > (err, restart)! <<<
2002-05-08 by Jeff
On Tue, 07 May 2002 13:01:38 -0000, drj0 wrote, > ... > I plan to replace everything in my setup > with the XL-7 and the RS-7000 .... > ... I've got an mp7 and an RS7000 (both for sale, btw). The mp7 is the better rompler. The RS7000 has superior sequencing and effects, which for my use delegated the mp7 to use as a sound module. If you are planning on using the mp7 as the main sequencer and are going to use the pads a lot, spend some time with one before you plunk down the money. Jeff
2002-05-08 by drj0
So why are you selling them? --- In xl7@y..., Jeff <drumcorps@e...> wrote:
> On Tue, 07 May 2002 13:01:38 -0000, drj0 wrote, > > > ... > > I plan to replace everything in my setup > > with the XL-7 and the RS-7000 .... > > ... > > I've got an mp7 and an RS7000 (both for sale, btw). > The mp7 is the better rompler. The RS7000 has superior > sequencing and effects, which for my use delegated the > mp7 to use as a sound module. If you are planning on > using the mp7 as the main sequencer and are going to > use the pads a lot, spend some time with one before > you plunk down the money. > > Jeff
2002-05-08 by mikexl7
You say the sequencer in the RS7000 is better. I am courious can you change from pattern from pattern on the fly with that unit? I know from using the RM1x that you could not do this making the xl a obvious choice for me. Just wondering. Mike G. --- In xl7@y..., "drj0" <drj0@y...> wrote:
> So why are you selling them? > > --- In xl7@y..., Jeff <drumcorps@e...> wrote: > > On Tue, 07 May 2002 13:01:38 -0000, drj0 wrote, > > > > > ... > > > I plan to replace everything in my setup > > > with the XL-7 and the RS-7000 .... > > > ... > > > > I've got an mp7 and an RS7000 (both for sale, btw). > > The mp7 is the better rompler. The RS7000 has superior > > sequencing and effects, which for my use delegated the > > mp7 to use as a sound module. If you are planning on > > using the mp7 as the main sequencer and are going to > > use the pads a lot, spend some time with one before > > you plunk down the money. > > > > Jeff
2002-05-08 by Jeff
> > > ... > > > I plan to replace everything in my setup > > > with the XL-7 and the RS-7000 .... > > > ... > > ... > > I've got an mp7 and an RS7000 (both for sale, btw). > > ... > So why are you selling them? The short answer: After I got through the bulk of the mp7 & RS7000 learning curves I found them too tedious compared to a computer based system. The long answer would cover a lot of subjective ground and various limitations of each box. Jeff
2002-05-08 by Jeff
On Wed, 08 May 2002 04:41:46 -0000, mikexl7 wrote, > You say the sequencer in the RS7000 is better. I am courious can > you change from pattern from pattern on the fly with that unit? > I know from using the RM1x that you could not do this making the > xl a obvious choice for me. Just wondering. The patterns are grouped into styles, 16 patterns per style. I found 16 patterns a reasonable limit to work within and treated "styles" as if they were songs comprised of 16 patterns or less. In that context, switching patterns is glitch free. One aspect of the RS7000 that I found very useful was the 5 mute memories. You can do things like break a pattern into two 8 track sequences that run at the same time, and switch between the two at any time without resetting the pattern back to beat 1:0:0 by toggling the track mute status(s). I.E. Toggle between tracks 1-8 muted and tracks 9-16 muted by tapping a button. A setup like that is very flexible and a lot of fun to play in real time. Stuff like midi based echo and swing can be tweaked [non-destructively] in real time, and can be applied to one track, tracks 1-8, tracks 9-16 or all tracks at once. Slave the xx7 to the RS7000 and leverage the xx7 rompler capabilities and you have one heck of a hybrid system for live work. Jeff
2002-05-08 by erik_magrini@Baxter.com
"Andre Lewis" <andrel@...>
05/07/02 12:10 PM
cc: Subject: RE: [xl7] Re: IS IT WORTH IT?!
If anyones interested I am selling an SP808 pro sampler with the added
inout/digital expansion card, sweet and perfect for a heavy duty DJ set.
drj0 <drj0@...>
05/07/02 11:18 AM
cc:
the RS7000
> for too?"
> rEalm
7000
about
enough! The
rewind
> (err, restart)! <<<
> ADVERTISEMENT
Service.
ADVERTISEMENT
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.2002-05-08 by erik_magrini@Baxter.com
If the sequencer is in the RS7000 is like the one in the RM1x then, sadly,
it is probably better than the XX-7's. I bought a RM1x awhile ago just
for it's sequencer and MIDI editing features (which are the best of any
groove box right now), but returned it after getting really sick of the
limit patch editing.
mikexl7 <mikexl7@...>
05/07/02 11:41 PM
cc: Subject: [xl7] Re: IS IT WORTH IT?! You say the sequencer in the RS7000 is better. I am courious can you change from pattern from pattern on the fly with that unit? I know from using the RM1x that you could not do this making the xl a obvious choice for me. Just wondering. Mike G. --- In xl7@y..., "drj0" <drj0@y...> wrote: > So why are you selling them? > > --- In xl7@y..., Jeff <drumcorps@e...> wrote: > > On Tue, 07 May 2002 13:01:38 -0000, drj0 wrote, > > > > > ... > > > I plan to replace everything in my setup > > > with the XL-7 and the RS-7000 .... > > > ... > > > > I've got an mp7 and an RS7000 (both for sale, btw). > > The mp7 is the better rompler. The RS7000 has superior > > sequencing and effects, which for my use delegated the > > mp7 to use as a sound module. If you are planning on > > using the mp7 as the main sequencer and are going to > > use the pads a lot, spend some time with one before > > you plunk down the money. > > > > Jeff To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks for the reply it gives me some insight on the RS7000. Peace Mike --- In xl7@y..., Jeff <drumcorps@e...> wrote: > On Wed, 08 May 2002 04:41:46 -0000, mikexl7 wrote, > > > You say the sequencer in the RS7000 is better. I am courious can
> > you change from pattern from pattern on the fly with that unit? > > I know from using the RM1x that you could not do this making the > > xl a obvious choice for me. Just wondering. > > The patterns are grouped into styles, 16 patterns per style. > I found 16 patterns a reasonable limit to work within and > treated "styles" as if they were songs comprised of 16 > patterns or less. In that context, switching patterns is > glitch free. > > One aspect of the RS7000 that I found very useful was the > 5 mute memories. You can do things like break a pattern > into two 8 track sequences that run at the same time, and > switch between the two at any time without resetting the > pattern back to beat 1:0:0 by toggling the track mute > status(s). I.E. Toggle between tracks 1-8 muted and > tracks 9-16 muted by tapping a button. > > A setup like that is very flexible and a lot of fun to > play in real time. Stuff like midi based echo and swing > can be tweaked [non-destructively] in real time, and > can be applied to one track, tracks 1-8, tracks 9-16 or > all tracks at once. Slave the xx7 to the RS7000 and > leverage the xx7 rompler capabilities and you have one > heck of a hybrid system for live work. > > Jeff
2002-05-08 by Andre Lewis
Sent: Wednesday, May 08, 2002 4:54 AM
"Andre Lewis"05/07/02 12:10 PM
cc:
If anyones interested I am selling an SP808 pro sampler with the added inout/digital expansion card, sweet and perfect for a heavy duty DJ set.
If you're just triggering phrases, I'd say sp808 or SU700. The RS7000 is really just an SU700 with the RM1x sound engine thrown in, and that sound engine isn't anywhere close to what you're getting with the XX-7 (ie, it sucks), so why pay for it? I had an sp808, and as long as you don't need more than 4 samples playing at once I'd highly recommend it. ;You can get a great effects in there, and back up to Zip is really nice too.
cc: ;
the RS7000
> for too?"
> rEalm
7000
about
enough! The
rewind
> (err, restart)! <<<
> ADVERTISEMENT
Service.
Buy Stock for $4
and no minimums.
FREE Money 2002.
