Possible P2500 bug, very annoying !
2002-05-01 by blueriv
Thanks in advance for any help (E-Mu tech support would be great too) with this issue/bug: My sends assignments are not being saved: Here is what I did to test this bug: - In the [Midi] section I make sure I am in "Multi" mode. - I go into [Global] section and set all my midi "A" channels 1-16 to a given send 1,2,3 or 4. I save the MultiSetup as "multi-1" or any name... - I make sure that the effects send param is set to "use master", not sure if right words, but I know that the presets are all using the sends and the master FXA and FXB setup. - I create a pattern but when it plays, it resets the send assignments to what they were before I set them in global, so I hear a tap delay where I should be hearing just 'verb. If I hit the [Global] button in the middle of the pattern playing, I select the "Multi-1" multisetup I saved and all my sends are back to normal and I hear verb where I should and tap delay where I should, but when the pattern recycles, they get reset again. - The same things happens to my mix volumes and pans !!! OUCH Why does the pattern play reset the sends to the default multisetup ?? Or better yet, why don't my sends assignments stay active ?? Please help, I am trying to finish a demo with the P2500 and this is causing a big delay for me... Thanks !! -Steve ;-}
