fx interaction
fx interaction
2002-04-29 by coscon23
the fx of my a2k automatically become the same as the fx from the
chosen mp-7-pattern. does anyone else have this problem with other
emu-gear?... is there a possible work-around?
peter.
Re: [xl7] fx interaction
2002-04-29 by Aaron Eppolito
Hook it up to MIDI Out B instead of A.  FX sysex is only sent out on MIDI Out
A.
Alternatively, if you must use MIDI Out A, you could set your Audity 2000 to
use "Preset on channel xx" effects instead of "Use master settings".
-Aaron
Re: fx interaction
okay... i'll try that... thanx a lot (again!)
on MIDI Out
> A.
Audity 2000 to
> -Aaron
