Archive for xl7.
Re: [xl7] Thanks Sean Wilhemsen!..Rec Arpegio Midi Data into Cubase
2001-09-20 by kudos
Brilliant Sean! Well explained...thanks very much.
Kudos
To: <xl7@yahoogroups.com>
Sent: Thursday, September 20, 2001 7:17 PM
Subject: Re: [xl7] Rec Arpegio Midi Data into Cubase
> To remove the held notes, you'll have to edit the track and erase the
> notes with the long duration's. They should be easy to spot and are
> probably located at tick 0 of the bar you first recorded into. Also,
> make sure your Xl-7's tempo is the same as your software Sequencer or
> better yet set the Xl-7 to slave to the Soft Sequencer via MIDI clocks.
> If you have input quantize on, it may faster and easier just to match
> tempos if you haven't already synched your two Sequencers together.
> sean at e-mu / ensoniq
