midi file import
midi file import
2002-04-12 by ugrr5
I have this problem when importing standard midifiles, I make in
cubase 5.0 into the command station.  lets say I export a 8 bar midi
file that was made in cubase. When its imported into the command
station it is now 10 bars long, with the first two bars being blank.
At first I though that it was maybe the two bar countin that I have
set in cubase, I disable that, no luck. I have tried saving in both
midi file formats. no luck there either.
Any suggestions
Gill
Re: midi file import
2002-04-12 by rob99brown
Gill,
Remove the midi count-in under options/synchronise.  That should fix
it.
Good luck,
Rob
midi
> Any suggestions
> Thanks
> Gill
