Archive for xl7.
Re: [xl7] MIDI issue
2019-07-08 by shook norris
ive got that message in all 2 command stations ive had and all were fine
Virus-free. www.avast.com
On Mon, Jul 8, 2019 at 11:14 PM Fred Smith rs6000jade@... [xl7] <xl7@yahoogroups.com> wrote:
Hello Community,
I was having some fun with the Command Station XL7 hooked up with Ableton Live. Anyway, the fun abruptly stopped. The issue was no more midi in to the EMU. I checked everything, the fault is in the EMU. When I run the diagnostic cycle  I get  the error message, "Midi loopback test midi port failed". So I have some sort of issue with the midi "; in" port. I have done the reset on the machine but still the same error. Everything else is fine.
Does anyone have any idea on how one could fix this, or what the error means?
Thanks so much!!
3 command stations
Hello Community,
I was having some fun with the Command Station XL7 hooked up with Ableton Live. Anyway, the fun abruptly stopped. The issue was no more midi in to the EMU. I checked everything, the fault is in the EMU. When I run the diagnostic cycle  I get  the error message, "Midi loopback test midi port failed". So I have some sort of issue with the midi " in" port. I have done the reset on the machine but still the same error. Everything else is fine.
Thanks so much!!
2019-07-09 by rs6000jade@...
Thank you Ray your advice was spot on, the midi issue is now cleared up. All good again talking with Ableton!!
Cheers!!
Re: MIDI issue
2019-07-10 by Fred Smith
Thanks for the tip that was very useful!
yes will explore the midi changes in multi-set ups.
Cheers!!
