Re: [xl7] E-Loader
2019-02-11 by Ray Bellis
On 10/02/2019 10:24, ricard2010@... [xl7] wrote: > It struck me that E-Loader is actually written in Java, so perhaps > it would work on a modern machine. I dug into the installation > directory and copied it all to a Linux machine (which is what I > normally used) and started the application. It actually ran without > any errors. However, I couldn't get it to recognize any MIDI ports, > perhaps not surprising, as despite the standardization of Java it > would most likely have been done very differently in Windws 98 than > today. Still, since there are no error messages, it seems as if it's > not expecting something that it cannot find in the environment. > Without MIDI connectivity it's pretty useless though of course. The E-loader app pre-dates the addition of javax.sound.midi to J2SE. It therefore uses a separate DLL (using JNI to add native code to Java apps) to gain access to the MIDI ports. > Has anyone else attempted this, or have some Java experience that > would help this getting going? For the firmware updater I did start to look at whether it would be feasible to replace the JNI DLL with calls to javax.sound.midi but it turned out to be easier to write a new tool. > On this topic, I find it strange that the XL-7 has functions in the > MIDI menu to dump patches, but not sequences. E-Loader dumps them as > standard midi (.mid) files, so I expect the format would be pretty > standard. Haven't dug into it at all though, just taking a top level > approach for now. I suspect that sequences are exchanged using MIDI file dump messages, which is fine if you've got E-Loader, but is generally not supported by generic sysex librarians. > I saw someone in the P2K group had written a web based tool for > firmware upgrading, so that's a starting point too. Steve wrote: > Perhaps someone (maybe Ray?) will write a user interface to > upload/download patterns/songs using webmidi. Or perhaps someone > with coding experience would want to write a standalone program. > I'd be willing to contribute thoughts and research if it would help. > IIRC the midi sequence dump requests are pretty straight forward. I'd consider it, but I don't have a P2500 or XP-7 to test with. Ray
