New OS comments
New OS comments
2002-04-10 by erik_magrini@Baxter.com
I would say that the relative lack of comments on the new OS is a good
sign.  Personally I think the new OS rocks, and makes the XL-7 95%
complete now (always gotta leave room for more).  Who wants to start a
"new features we want now" thread?  :)
(proper RPS and Megamixing would be cool)
(one of the reasons i haven't been able to check out the new os yet... by
the way... is everybody happy now?...
not much people commented on it...)
RE: [xl7] New OS comments
2002-04-10 by John Royle
Me! Please, please, please, can somebody add a feature that reloads the last multisetup used when the box was last turned off. Every day, the first thing i have to do with my xl-7 is turn it on, then manually reload the last multi. One step on from that would be to do what my Virus does and that is when you turn the box off, and on again *everything* is just as how it was left.
Sent: 10 April 2002 14:48
Subject: [xl7] New OS comments
I would say that the relative lack of comments on the new OS is a good sign. Personally I think the new OS rocks, and makes the XL-7 95% complete now (always gotta leave room for more). Who wants to start a "new features we want now" thread? :)
(one of the reasons i haven't been able to check out the new os yet... by the way... is everybody happy now?...
That's not right, it shouldn't be doing that.  Mine is always the same
multisetup when I power back on.
the last multi.
Re: [xl7] New OS comments
2002-04-10 by Jonathan El-Bizri
- live undo/cut for live recording and looping, if possible with overdub and feedback tools ala Echoplex Digital Pro, Repeater
- more realtime performance tools, like the RM1x
- midi import to arpeggios
- switch between songs without stopping
- midi over USB, like all those midi USB ports
Sent: Wednesday, April 10, 2002 7:08 AM
Subject: RE: [xl7] New OS comments
2002-04-10 by Sean Wilhelmsen
The Xl-7 will load the last saved Multi setup. If you save you the Multi
before you turn your Xl-7 off it will load that Multi at boot up.
sean at e-mu / ensoniq
2002-04-10 by Andre Lewis
Everything I can think of really is on the wishlist in yahoo groups databases. The only thing that would be super sweet would be the undo.....
Sent: Wednesday, April 10, 2002 6:48 AM
Re: New OS comments
2002-04-10 by mikexl7
Ya that is totaly odd.  mine is also fine in that respect.
Mike G
same
> rEalm
reloads the
reload
> the last multi.
2002-04-11 by John Royle
Doh! I feel really silly now! For some reason i didn't think that it did... i'll check tonight just in case it's all a big conspiracy to make me look stupid. ; That must be the quickest bug-fix in history ;)
2002-04-12 by John Royle
> Doh! ; I feel really silly now! For some reason i didn't think that it did...
> stupid. That must be the quickest bug-fix in history ;)
Hi guys, i just tried the multisetup re-load thing last night, and i'm quite sure it isn't working. This is what i did:
1. Turn on the XL-7 and load one of my multi's
2. Change some of the channel/preset assignments
3. Save my multi.
4. Sequence some beats using my PC, and they all come out correct.
5. Save again for good measure.
6. Turn off the XL-7, and then turn back on.
7. Play my sequence off my PC
8. The beats are now playing the wrong drum sounds
9. Restore my Multi from the Global menu
10. Play the sequence again and all is fine.
So, is this what should be happening or not?? Is it because when i start up the box it always goes to Song 000 and therefore loads the correct multi setup for that song??? It's annoying because i never really use the sequencer stuff on the XL-7, i just use it mainly as a sound module, so i'm only interested in the multi setups and not the song stuff.
john.
Re: New OS comments
2002-04-12 by mikexl7
Ok got a couple of questions for you.
Main one being are you selecting the pattern that you saved the
multisetup to?
you will always have to do this, if this is the case it is not hard
to do.
If you want it to default to one multisetup each time just save the
multisetup that you want it to be when you turn it on to the first
pattern.
hope that helps.
mike
i start up
multi
module, so i'm
> john.
2002-04-12 by erik_magrini@Baxter.com
Sound fine to me.  Actually that's what Multi's are for, so you're using
them correctly.
3. Save my multi.
john.
Yahoo! Groups Sponsor
ADVERTISEMENT
ok, so what is the relation of multi's to songs? What i want is to turn the box on with the last multi i used in place. So, if i load a multi, does the box then assign that multi to the current song? So when the box turns on it loads the multi for song 000?
Ok, so what i need to do is load the multi i want, then save the SONG at posiiton 000. Then when i start up the box, it will initialise with song 000 and load the multi that i saved with that song???
I think what was confusing me was i was treating multi's as being completely unlinked to songs.
john.
Sent: 12 April 2002 13:04
Sound fine to me. Actually that's what Multi's are for, so you're using them correctly.
3. Save my multi.
john.
ADVERTISEMENT
They are totally unrelated to songs.  A multi is a snapshopt fo all the
settings in your XL-7 at the time that you save the Multi.  This includes
all preset, volume, pan, and effects.  If you want your XL-7 to power on
wioth the same settings everytime based on a particular song, select your
song, then play it so that the presets and effects all load.  After a
second, stop playback, then resave the current multi.  When you power
off,t he box should power back up with the multi you just saved.  If not,
just reload it, it only takes 2 seconds.
john.
them correctly.
3. Save my multi.
john.
ADVERTISEMENT
ADVERTISEMENT
2002-04-12 by Sean Wilhelmsen
John, This is what I believe you should do for your setup and its very
simple. Copy an empty Pattern into Pattern 000. What's happening is, the
Multi is loading correctly, but Pattern 000, Arctic Drift is then
loading a sub set of Multi features to support the pattern. With an
empty pattern in location 000, your loaded Multi will be untouched.
> Multi
> it did...
> look
> 3. Save my multi.
> song stuff.
> john.
>                        ADVERTISEMENT
>                        [Click Here!]
2002-04-12 by Alex Strudley
When your beats are playing wrong, it is playing from a default multi
that loads at Poweron, since it fires up in pattern mode.  The XL7 is
acting correctly.  I sometimes use the box the same way. You are doing
everything correctly. Just save your multisetup and when you power up
your computer and your XL7 everytime you start sequencing, load that
multisetup you have saved.  I find it works easiest if whatever sequence
I am working on on my computer using the XL-7, I always save that
multisetup as multisetup 00 and I always call it new song or something
like that. Easy way to keep track of things.  Then you just have to load
that up when you are powering everything on and you are ready to go!
Al
> Multi
> it did...
> look
> 3. Save my multi.
> song stuff.
> john.
                        ADVERTISEMENT
                         [Click Here!]
