Hi Steve,
thanks for your answer.
Yes, I have OS 2.0.
Blinks was found. I just thought it should blink while I'm tweaking the pots during EDIT. Instead, it blinks during PLAY.
That's OK.
Regarding your other answers:
I'm not a native English speaker, and I found the
In this mode, each of the 16 knobs will control MIDI Channel Volume for
the like-numbered channel. This directly edits the value shown on the
preset select screen and is equivalent to sending MIDI cc#7.
paragraph confusing. Confusing in that I interpreted the "equivalent to sending MIDI cc#7" words as SENT TO THE XL7, aka INCOMING MIDI CC7.
I understand external control and it's OK.
I just thought per the manual there's an option to explicitly block sending CC7, while other CCs are sent.
Clearly that's not the case and I can understand why, and it's logical.
I wanted to accomplish separate volume control from the XL7 surface alone.
That's not possible. So I have to reach to the external instrument and control volume there if
I want different (temporary or fixed) levels for internal and external sounds. Not a too big hassle, but still...
Of course I can implement a MIDI filter inbetween the XL7 and extrnal instrument, if all else fails.
Thanks.
Zsolt
