Archive for xl7.
knobs etc malfunction- hardware or software problem?s
2016-02-22 by shad_dart@...
Hi, thanks to those who responded to my post about wtb a manual.
I have discovered that when I set the 16 knob selector to "volume", some knobs control 2 channels, and some none (ie in mix mode).  to be exact:
knob 1 controls channel 1 and 7
knob 2 controlls channel 2 and 17
knob 3 controls channel 3 and 14
knob 4 controls nothing
Is this a sign of failure of the knob board itself, or could this be a software glitch.
the unit came with 2.0 -
Any help would be appreciated _ i would be sad to return it because it is so cool
PS a couple pads behave irregularly, and the mod strip is also a little glitchy- I notice that
all these hardware parts are for sale, I just want to know from you experienced dudes if replacing
the hardware components would solve this problem.
thanks again, I appreciate the help!
Paul
Re: [xl7] knobs etc malfunction- hardware or software problem?s
2016-02-22 by Matt
Open it up and look inside see if there is capacitors leaking or something. You can check all the knobs with multimeter and see what9;s the issue.
Paul
Re: knobs etc malfunction- hardware or software problem?s
2016-02-23 by shad_dart@...
Hi- I have opened up the unit- could anyone tell me how to test the 4 terminal pots?
with light and magnification I see no evidence of leaky capacitors or anything else awry.
Thanks in advance for any help!
Paul
