I had a similar problem that was caused by corrosion from leaky capacitors in the power supply. The electrolyte corroded the board just enough to cause the low C pad not to work. I always recommend recapping or replacing the power supply--I've seen a lot of bad ones, both in the Command Stations and the rackmount P2K family.
