Unwanted send to effects
2016-01-23 by brian.grassfield@...
Hi! I have a question if someone experienced the same: how the effects mix-in could set apart with the common way? I started with a rom patch and my global was set to use fx of the patch used on channel 1. Then I recalled the patch to edit and set all fx send to 0% and... it sends a bit anyway! So literally if I set this patch to fx source then I cannot make dry sounds. I checked this with many other patches and patterns, but this was the only which behaved this way. Can someone make an advice, what to see for fx send amount?
