Archive for xl7.
Re: [xl7] Saving pattern for patches set-up
2015-11-29 by Greg Waltzer
You can save the assignment of presets to channels as a multi.
On 11/29/2015 2:22 AM, mindkil@... [xl7] wrote:
> Hello!
> I would like to save a set-up of patches on different channels on my
> XL-7 - eg. Ch.1 = Preset 001, ch.2 = Preset 024, Ch.3 = Preset... so
> that I can easily have access to different sounds while playing live,
> by switching to the appropriate Channel.
> Unfortunately when I save the Pattern, it doesn't save the set-up of
> instruments on the Channels I didn't record any sequencer information
> - it gets lost when I turn off the XL-7. Is there some workaround for
> this?
> Bests,
> Gas
Re: Saving pattern for patches set-up
2015-11-30 by smw-mail@...
In addition to Greg's suggestion there's another one that involves basically setting up patterns as templates with dummy data so the channel data gets saved with the pattern. Some background: when  saving a pattern, if there is no data on a particular track, it gets interpreted as an empty track.  I have used this technique to preserve (for example) channel assignments, etc.
In addition to your preset data, you could enter CC 7 as 127 on each channel (or any other data).  Then save the pattern.Hope that helps.
--Steve
Yes. Also, you might want to test inserting presets as data to see if that is enough dummy data to prevent tracks from going into an empty/default state when saved. I was wondering about that. I mght test it myself and possibly post some template examples.
--Steve
Re: [xl7] Re: Saving pattern for patches set-up
2015-12-20 by Sean Wilhelmsen
The preset is saved when�you�engage record.�It's saved�as data, pre start�of the pattern.��If you make 16 dummy tracks for�a one measure pattern with the desired presets assigned to the tracks�, record without notes and then save. The next time you select the pattern it should load all of the presets, volume, and pan information without�having to press start. As Steve mentioned you can then uses this as a template for further setups.
Sean
On Monday, November 30, 2015 4:43 AM, "smw-mail@... [xl7]" wrote:
Yes. Also, you might want to test inserting presets as data to see if that is enough dummy data to prevent tracks from going into an empty/default state when saved. I was wondering about that. I mght test it myself and possibly post some template examples.�
--Steve
