Index last updated: 2026-04-03 18:22 UTC
Recording BTS triggers again!
2002-04-08 by grimleyj2000
OK,
So I have read all your replies and I am even more confused :-)
What exactly is BTS for??  Is it for demo purposes?
There doesn't really seem to be any correlation between patterns and
BTS.  BTS will continue playing even after the pattern is stopped.
Triggers do not bring BTS parts in on the beat (e.g not in sync with
the pattern), unless you hit Audition to bring the BTS in.  Also you
cannot record the BTS parts in pattern or song mode.
Are all these assumptions correct?  Also how do you make your own BTS
presets (as some of you seem to be doing.)
The BTS riffs do sound very cool (I spent over an hour jamming with
Rocket ... I think that's what it is called), but either I am not
using them correctly or they are not very well integrated into the XL
interface.
Does the XL1 Xtreme Lead behave the same?  Maybe the XL-1 manual will
shed some light ... I'm off to find it now.
Justin.
Re: Recording BTS triggers again!
2002-04-08 by emufreak1
Justin,
Page 44 in the XL-1 manual sums it up.
M2
--- In xl7@y..., "grimleyj2000" <grimley@i...> wrote:
> OK,
and
with
you
BTS
XL
> interface.
will
> Thanks,
> Justin.
> > OK,
Fun!
> and
Yes and no.  (NO first)If your trigger buttons are unlatched, the BTS
sequencer will stop running as soon as you lift the note on key(s).
If the triggers are latched then 1 press turns the part on (note ON)
and the next press turns the part off(note OFF).  There are 16 parts
that can be triggered individually.
> with
You have to have the parameter "use current tempo" enabled or else it
will use the BTS riff tempo which will not sync with your stuff
unless it happens to be the same bpm.
  Also
> you
You can if you apply the proper note ON/OFF messages for parts needed
throughout your song and the "use current tempo" is set correctly.
> BTS
with
> XL
> > interface.
> will
> > Thanks,
> > Justin.
Re: [xl7] Recording BTS triggers again!
2002-04-09 by erik_magrini@Baxter.com
>>>I assume it's short for "Beats mode". <<<
>>>No, although it could be used that way I suppose. <<<
>>>When using BTS. It's best to thing of your XL-7 as having two
sequencers, the main one and the BTS one.  They can run independantly of
each other, or synced up, it's up to you how to use them. <<<
Triggers do not bring BTS parts in on the beat (e.g not in sync with the
>>>The box can't do EVERYTHING for you!  A sense of timing is good to have
when doing electronic music, no? <<<
Also you cannot record the BTS parts in pattern or song mode.
>>>Yes you can, set the BTS part to unlatched and record the Trigger press
while you sequencer is set tot eh right MIDI channel. <<<
Also how do you make your own BTS presets (as some of you seem to be
doing.)
>>>It's easy, just pick a Preset (any will work), then press Preset Edit,
and scroll to the audition/riff page.  From here, move the cursor to the
lower line an select any Uadition riff with "BTS" before it, and save the
Preset.  Bam, you're done! <<<
The BTS riffs do sound very cool, but either I am not using them correctly
or they are not very well integrated into the XL interface.
>>>Probably both, no offense.  BTS are cool to a point, personally I think
it would rock to be able to make your own, but anyway...  Just keep
thinking of BTS as Audition Riffs that have 16 parts and you're halfway to
understanding the feature.  As for integration, I think that the box does
the best it can do, but yeah it could be slightly more streamlined to make
it easier.  They basically threw it in after the fact to address people
wanting RPS features in the XL-7.  I told Aaron they were going to get A
LOT of questions on this feature when they released the new OS :) <<<
Maybe the XL-1 manual will shed some light ... I'm off to find it now.
>>>Try the Orbit 3 one too, although I think you'll find they're almost
identical manuals for that section. <<<
2002-04-10 by grimleyj2000
press while you sequencer is set tot eh right MIDI channel. <<<
Realm,
Thanks for the lengthy reply ... appreciated.  I am not having much
luck though with recording the triggers.  I have a BTS preset on
channel 2A - bts:Trancer.  I have the Trancer bts riff assigned to
it from the Preset edit menu.  I then go into the ARP / Beat keys
Layout menu and change all the parts 1-16 to unlatched.  I still
cannot record the triggers on channel 2.  I can hear the BTS when
recording but when I play back the pattern ... nada.  I also tried
changing the BtsCh and TrigCh.
Any suggestions?
Justin.
Re: [xl7] Re: Recording BTS triggers again!
2002-04-10 by erik_magrini@Baxter.com
Are you using the pads or the trigger buttons?  I think you'd need to use
the pads, sorry I should have added that in my last reply.  The diagram
for the correct keys is in the new Addendum BTW.
"grimleyj2000" <grimley@...>
04/09/02 11:06 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Recording BTS triggers again!
Realm,
Any suggestions?
Justin.
2002-04-10 by emufreak1
http://groups.yahoo.com/group/xl7/files/beatkey.jpg
Grimley,
Refer to the above file and try using your *keypads on your unit
instead of the trigger buttons.  Play around with the transpose
button until the first pad(C)gives you the kick drum on Trancer.
(C#1) will give you snare and (D)will give you hi-hat and so on.
Now with the BTS parts set to either latch or unlatched, try
recording the parts.  If you have the parts needed unlatched, you
will have to hold the pad down until you want it to stop(note on/off
command), if you have it set to latched, you can press the pad once
(note on) and come back to it when you want it to stop by hitting the
pad again(note off).  Each part has it's own velocity setting as
well.
Try it out.
Later,
M2
Trigger
> Realm,
> Any suggestions?
> Thanks,
> Justin.
If that doesn't work for you, refer to page 5 on the OS 1.31 addendum
page 5(top).  It says to set the trigger button feature to "play
beats parts"
Later........
> Grimley,
on/off
> well.
> Try it out.
> Later,
> M2
> Trigger
> > Realm,
much
to
tried
> > Any suggestions?
> > Thanks,
> > Justin.
2002-04-12 by blueriv
In my case, I have a Proteus 2500 with no keypad, so I connect a midi
keyboard on it and use the beats keymaps to start/stop. Was able to
record my BTS patterns to the internal sequencer with no problem that
way, was not able to record BTS via triggers from command functions
while recording.... You can also use a sequencer like Sonar or Pro
Tools to trigger the BTS patch and record either in the software
sequencer or the built in sequencer. Works like a charm... But I
still have not figured out how to bring in the different
group/variations, still learning.... -Steve
Re: Recording BTS triggers again! Aaron ... any suggestions?
2002-04-13 by grimleyj2000
M2,
Thanks for the reply.  I have setup the BTS mode as you said.  I
have the first part of the Trancer BTS (kick) triggered on the first
pad (C)at the lowest transpose setting, snare on c# etc.  Now when I
try to record I can hear the BTS play, but when I hit stop then
playback the pattern, all I hear is a Kick no matter which pad I had
recorded.
-grimley
addendum
> beats parts"
> Later........
> > Grimley,
you
> on/off
once
hitting
> the
> > well.
> > Try it out.
> > Later,
> > M2
> > Trigger
> > > Realm,
> much
on
assigned
> to
keys
still
when
> tried
> > > Any suggestions?
> > > Thanks,
> > > Justin.
