Archive for xl7.
hot power supply
hot power supply
2015-03-17 by rogers t
It's worth noting that many of these emu boxes made use of bootleg capacitors in the power supply (as did many computers of the same era.)  The caps can leak and cause damage to circuit boards, and as they fail they often cause erratic behavior of the machine.  For most members of the P2K and XL7 family, a power supply recap is highly recommended.  I have seen a few late model P2K boxes that have an updated power supply, and it's possible some of the later Command Stations do as well.  But as a general rule, a power supply recap is the way to go.
Re: [xl7] hot power supply
2015-03-18 by Brian Grassfield
How can it be done? Custom soldering out old capacitors?
On Tuesday, March 17, 2015 10:52 PM, "rogers t winky_dinglehoffer@... [xl7]" wrote:
RE: [xl7] hot power supply
2015-03-18 by Ryan, David
You take out the existing Electrolytic Capacitors and order new ones with the same capacitance, voltage rating, lead spacing, diameter and height (smaller diameter and lower height is fine). You can find replacements at places like Digi-Key, Mouser or Newark (in the US at least).
