Re: [xl7] filter bypass
2015-03-17 by eidorian@...
On 2015-03-16 21:29, topgeneral2002@... [xl7] wrote: > Hello all I want to send the sounds from my MP7 through my se1x but I > want to bypass some or all effects from the mp7 so that the se1x is > doing the job. How can I bypass the filter of the mp7 and other > effects? > Thanks > Reginald You can turn effects off easily enough (Global Menu -> Master Effects -> FX Mode -> disabled), but filters are per-note played and often have shape which changes over time. So unless you're using the MP7 as a monosynth (or one monosynth per audio output jack I guess) you will be rather limited on what filter shaping you can achieve on notes (basically you'd end up with a paraphonic filter like the Korg Poly-800, at best). I very much doubt there's a feature to "turn the filter off" (i.e. open the cutoff frequency to maximum and set resonance to 0) globally - it's hard to see why anyone would want do that, so I wouldn't expect EMU to put that functionality in. I've seen nothing in the manual about it. Cheers, A.
