Archive for xl7.
Advice on backing up all my presets needed
2015-02-12 by electrow2000@...
I need to back up my presets to the computer (Win7 32 or 64bit). I've downloaded the Prodatum editor but I can't tell if it saves all the presets or just one at a time. Maybe I've missed something while reading the manual. If Prodatum is not designed for bulk dumps of presets what is recommended? I understand e-loader is not for saving presets - correct?
Re: Advice on backing up all my presets needed
2015-02-13 by rpcfender@...
Just to be clear, you have pressed the MIDI button and are at 'SEND MIDI SYSEX DATA' ?
Cursor down and select say 'bank 0 user presets'
Press the flashing Home/Enter.
The CS send should light and the counter on the manual dump in MidiOx should start counting if you have the  connected Midi interface selected as a device in Options/Midi Device... in MidiOx.
This is all that should be required as far as I know and works perfectly on my system.
The fact that you are not seeing Midi out led light up on the CS means the problem is in the CS.
2015-02-13 by electrow2000@...
Thank you rpcfender. The answer is yes and as I was dreading midi out doesn't light. I hate to go into diagnostics mode without first having backed up my presets - back to square one, I guess.
Re: [xl7] Re: Advice on backing up all my presets needed
2015-02-13 by First Last
does your midi device support sysex?� a lot of them dont these days
