Archive for xl7.
Where is the SYSEX data on EMU.com?
2001-08-11 by RW Pointer
I am reading the manual and it says that the sysex data is
available online because it is too large to include in the manual.
I am interested in learning how one would use the command
station to make a patch change on a external synth that it is
controlling.
Anyone know how to do this?
Thanks!
rob.
Re: Where is the SYSEX data on EMU.com?
2001-08-11 by sserendipity@newsfeeds.com
I haven't tried it, but I would assume that a patch change message
would be very easy to embed in a track, if you are using an external
sequencer for track construction. Since it would receive the patch
change message every time the loop went round you'ld probably need to
program it during a pause - unless your synth is capable of
instantaneous patch changes. Most of my gear wouldn't be able to do
this seamlessly.
However, I you mean embeding it in the trigger pad, it probably can't
be done, at least with the current OS.
> controlling.
> Thanks!
> rob.
hmmm, thanks for the response.
I am thinking in these terms -
Let's say I am using a Virus kb, and I am using the command
station to control it (as well as other gear as well).
I select another User Pattern bank because I am finished with
that particular song/pattern currently being played by the XL7. So
I select another pattern user bank that I created on the XL7, can I
have the command station send MIDI commands to the Access
Virus to change its patch as well (i.e. to the one I need for this
new pattern bank), or do I need to manually change the patch on
the Virus to play a new sound/patch for my new XL7 pattern I am
now moving on to (like on MIDI channel 16, for instance)?
I would think this would be a great addition to the unit if it can be
done as it would definitely ease playback anxiety in a live
performance situation. Especially if you could embed this
command in a track(s) for many external pieces of gear.
rob.
message
external
patch
probably need to
able to do
> this seamlessly.
can't
manual.
> > controlling.
> > Thanks!
> > rob.
2001-08-13 by sserendipity@newsfeeds.com
I agree, being able to place Patch changes and other 'setup' commands
is an essential feature of a live hardware sequencer - not only when
using it with other synths, but to control anything placed on the
units sub-outs.
I've only just started powering up the fx in my live rig, so I
haven't worked out how they will behave yet. Further experimenting to
follow.
Emu guys, I was wondering where we should file feature requests and
bug reports. Is this a good forum for them, or would you prefer them
offline?
sserendipity (listening to his xl-7 bleeping away the tune he just
uploaded to the xl-7 group's "files" section)
Re: [xl7] Re: Where is the SYSEX data on EMU.com?
2001-08-14 by Sean Wilhelmsen
> offline?
This is a good forum to report your requests.
sean at e-mu / ensoniq
