Archive for xl7.
Question about PX-7 sequences
2014-10-19 by smw-mail@...
A new member had a question, but it seems to have been cut off. (See below.) I believe the question is, will the sequencer banks be available in the PX-7 if the PX-7 ROM is installed.
Pattern and song slots are really empty slots.  The factory patterns and sounds would have to be loaded in using e-loader--assuming you have a PC and a midi interface that works with e-loader 1.1.
The E-Mu Commands Station and P2500 sequencer uses bank switching to point to presets on the ROM.  So, with a working e-loader/PC setup you could actually send the patterns to the empty PX-7.  I believe they are in the files section.
However, you won't hear anything play because there is no ROM with samples, multisamples, and presets installed.
Hmmmm.  Were the patterns wiped clean from the PX-7?
Anyhow, I hope this helps.
Steve
>I have an XL-7, and just recent purchased a PX-7, however, the PX-7 is
> missing the Protean ROM, and I have some questions about the ROM if I
> purchase a new ROM, will the sequencer banks be ava
