>A few people suggested I just send the new version out, since th file is
>so small. So here it is:
Thanks.
Here's something to correct:
>-Do the Command Stations have a GM mode?
>In stock form the factory the Command Stations do not have a GM mode. You
>can get GM sounds to use only if you purchase the Sounds Of The ZR ROM
>which has a GM
>Instrument bank.
That implies that it might have GM mode at that point. It doesn't.
Perhaps you should change it to: "If you buy the "Sounds of the ZR" ROM,
you'll have a full set of 'GM' sounds, but they still won't be assigned
automatically in a 'GM mode.'"
And for each of these cases:
>-Is there any way to initialize a Pattern to it's default settings?
>-Is there anyway to initialize a Preset to it's default settings?
> and that your Command Station is
>connected with both it's MIDI in
>This usually only happens if you are
>holding a note when the Patterns loops back to it's beginning,
>it may be best to use that hi hat Preset on it's own Track.
>because the value is
>already at it's maximum.
you should have "its" rather than "it's." I-T-apostrophe-S means "It is."
(And you use it correctly in other spots in the FAQ, such as "While it's
not possible to modify ...")
* Radio Free Entropy: http://just-john.com/cn/rfe.shtml *
