2014-07-11 by janoch23@...
By the way, are there any unmentioned parameters that can be controlled by sysex? Such as greater control over the effects engine than what is offered though the knobs and buttons. Or possible out-of-range parameter values.
2014-07-11 by smw-mail@...
(1) Get the sysex manual. That has a pretty good list of what you can control with sysex.
(2) I'd have to look, but offhand I don't think there are parameters that you can't access through the front panel. (Not 100% sure, though.)
(3) So far as I know, out of range values will not produce much of anything; though the sysex manual isn't 100% correct as far as some of the min/max values.
(4) There are undocumented sysex commands, but these will not give you undocumented parameters so far as I have seen.
Steve
