korg es1
korg es1
2002-04-04 by ph.demoor@free.fr
Sorry if it's a bit off topic , but I'll like to know what users think
about the Korg ES1 ..is it better than the Boss sp303 to play samples
with our Xl7 ?
Re: [xl7] korg es1
2002-04-04 by just john
>with our Xl7 ?
Don't know the 303, but I enjoy my ES-1.  It's especially useful if you get
a smartcard thingie on your main computer, 'cuz you can hone samples there
and transfer them to the Korg.  (It's also useful for backing up the ES-1's
data.)
* Radio Free Entropy:  http://just-john.com/cn/rfe.shtml *
RE: [xl7] korg es1
2002-04-04 by Andre Lewis
I'm about to go pick up my second one today!  Heheh I have a Roland SP808, which
I originally sold the ES1 for.  The SP808 is great, CD quality and professional
editing environment.  I had an ER1 so I wasn't worried about it.  I'm picking it
up again because it has a better sequencer than the ER1 and it's perfect for
programming the XL-7.  As far as sample quality, it uses 1/8th inch headphone
jack style inputs, is kinda dodgy to edit loops, and only does 38khz sampling.
The timestretch on it is totally a pain in the ass.  I've since picked up a
Yamaha A5000 which makes my SP808 redundant, so I'll probably sell that.  Let me
know if you want to buy it, I have the digital I/O for it and I'm planning on
selling it for about 500$.
Andre
Sent: Thursday, April 04, 2002 1:04 PM
Subject: [xl7] korg es1
with our Xl7 ?
Re: [xl7] korg es1
2002-04-05 by erik_magrini@Baxter.com
I would say yes, the ES-1 is a very cool little beast.  I was in the same
boat as you a couple months ago, sp303, or ES-1.  I'd go with the ES-1
definitely!
ph.demoor@...
04/04/02 03:04 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
with our Xl7 ?
Re: [xl7] korg es1
2002-04-05 by Roger Powell
I have both an ES-1 and the SP-303 (plus the SP-505.)
Here are my opinions.
The ES-1 is better at programming/playing patterns
where the individual samples are one-shot single
percussion instruments (like a drum machine.) The
fixed sampling rate is 32kHz which may make a
difference to your application. You can't save/load
individual samples to the smart media card; you have
deal with the entire machine contents at a time. This
also implies that a higher-capacity smart media card
does not extend the maximum sampling time.The effects
enable some fairly warped resampling that can be cool.
The SP-303 is better at playing sample loops where the
beat pattern/sounds is fully contained in the sample.
The 303 is also far superior for use in live 'DJ'
style sampling. Max sample rate is 44.1kHz and WAVE
files can be imported through the smart media card
(first you have to copy them onto it from a computer
interface.)  Maximum sampling time is increased with a
higher-capacity smart media card. The effects are also
very good, I think, for the intended purpose of
mangling for resampling.
The SP-505 adds more extensive pattern and song
programming capability, many more banks in which to
store samples, a good mix of functionality between the
two machines (SP-303 and ES-1.) However, because of
the menu structure access to functions, the 505 is
less "immediate" in live usage than the 303.
If you want to sample your own one-shots and build
step sequences, then the ES-1 (or SP-505) is great. If
you want to deal with sample loops, the SP-303 (or
505) is better.
Forneau
> definitely!
> rEalm
> ph.demoor@...
> 04/04/02 03:04 PM
>         cc:
> with our Xl7 ?
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
Re: [xl7] korg es1 (correction)
Let me correct one statement I made about
loading/saving samples on the ES-1:
You *can* load individual samples, either ES-1 format
from one of the saved back-up files or WAVE (32kHz)
from the smart media card. You are, however, still
limited to the 4MB internal memory limit for all
sounds/patterns/songs.
Another nice thing about the ES-1 is the format
conversion utility for your PC that let's you take
samples recorded directly into the ES-1 and turn them
into WAVE files. As far as I know, the Roland units
(SP-303/505) do not offer such a s/w utility.
 I like sampling directly into the machine, then be
able to tweak externally in a computer audio program,
then load back into the little sampler.
This utility be downloaded from the Korg ES-1 site.
Forneau
> SP-505.)
> This
> effects
> cool.
> the
> sample.
> a
> also
> the
> If
> 505) is better.
> Forneau
> > definitely!
> > rEalm
> > ph.demoor@...
> > 04/04/02 03:04 PM
> >         cc:
> > with our Xl7 ?
> Do You Yahoo!?
Do You Yahoo!?
RE: [xl7] korg es1 (correction)
2002-04-05 by Andre Lewis
If your after a DJ tool, don't get the es1, you won't be able to load enuff
samples.  If your after a kickass drum/sample sequencer, totally different
story. If your after a drum sequencer, It's practically a must.  Customm drum
hits, superb.  Long phrases with clips from soundtracks, well you simply don't
have enuff room loadable at one time on it. The SP-808 can dump wav files back
and forth on a zip100 disk, up to 44khz and a 100mb size.  You can resample
through it's kickbutt effects etc, sequence and multitrack.  For DJ work you may
want to look on ebay for one.
Sent: Friday, April 05, 2002 11:06 AM
Subject: Re: [xl7] korg es1 (correction)
Forneau
> SP-505.)
> This
> effects
> cool.
> the
> sample.
> a
> also
> the
> If
> 505) is better.
> Forneau
> > definitely!
> > rEalm
> > ph.demoor@...
> > 04/04/02 03:04 PM
> >         cc:
> > with our Xl7 ?
> Do You Yahoo!?
Do You Yahoo!?
