Help needed for easy change of midi notes
2013-03-22 by stefan
Archive for xl7.
Hello everybody! I like to sketch out my tracks on the XL-7 and then sequence my sampler (Emu Esynth) with the XL-7. I got my samples organized in 128s, one sample on each note. So I'm wondering if there's an easy way to browse thru my samples by changing the midi notes of a track (especially individual drum tracks). Any feedback will be highly appreciated! :-) SB
2013-03-22 by Bruno
Hello everybody!
SB
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/xl7/join
(Yahoo! ID required)
xl7-digest@yahoogroups.com
xl7-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
Thanks, Bruno. I know about transposing, but in that case I actually have to commit first in order to hear the kick in its context, for example. What I'm wondering is if there's a way to sort of scroll thru midi notes assigned to different kick drums for example, listen to the pattern of the kick drum, in the context of the track and THEN commit. I'm not sure if I made myself clear... SB --- In xl7@yahoogroups.com, Bruno <brunorc@...> wrote: > > You can transpose contents of selected tracks in a pattern, also specifying > the range (so only certain notes would get transposed). > > XL-7 manual, Rev. G, page 86. > > Bruno > > > 2013/3/22 stefan <nyatollah@...> > > > Hello everybody! > > I like to sketch out my tracks on the XL-7 and then sequence my sampler > > (Emu Esynth) with the XL-7. I got my samples organized in 128s, one sample > > on each note. So I'm wondering if there's an easy way to browse thru my > > samples by changing the midi notes of a track (especially individual drum > > tracks). > > > > Any feedback will be highly appreciated! :-) > > > > SB > > > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > >
2013-03-22 by Bruno
SB
> 2013/3/22 stefan
> Bruno
> > Hello everybody!
> > tracks).
> > SB
> > Yahoo! Groups Links
Yahoo! Groups Links
2013-03-22 by dutchbeats
a shortcut for restoring a pattern is to instead skip to an adjacent pattern, press record, then skip back to your pattern and it will be restored --- In xl7@yahoogroups.com, Bruno <brunorc@...> wrote: > > Yes, you did. > > Actually, pattern editing is a two-phase commit, so you can save your > pattern, transpose some stuff, and if you don't like it - restore the > pattern to the saved version, or save it. A bit of hassle, but still with > the possibility to revert bad edit. > > HTH, > > Bruno > > > 2013/3/22 stefan <nyatollah@...> > > > Thanks, Bruno. I know about transposing, but in that case I actually have > > to commit first in order to hear the kick in its context, for example. What > > I'm wondering is if there's a way to sort of scroll thru midi notes > > assigned to different kick drums for example, listen to the pattern of the > > kick drum, in the context of the track and THEN commit. I'm not sure if I > > made myself clear... > > > > SB > > > > --- In xl7@yahoogroups.com, Bruno <brunorc@> wrote: > > > > > > You can transpose contents of selected tracks in a pattern, also > > specifying > > > the range (so only certain notes would get transposed). > > > > > > XL-7 manual, Rev. G, page 86. > > > > > > Bruno > > > > > > > > > 2013/3/22 stefan <nyatollah@> > > > > > > > Hello everybody! > > > > I like to sketch out my tracks on the XL-7 and then sequence my sampler > > > > (Emu Esynth) with the XL-7. I got my samples organized in 128s, one > > sample > > > > on each note. So I'm wondering if there's an easy way to browse thru my > > > > samples by changing the midi notes of a track (especially individual > > drum > > > > tracks). > > > > > > > > Any feedback will be highly appreciated! :-) > > > > > > > > SB > > > > > > > > > > > > > > > > > > > > ------------------------------------ > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > > >
2013-03-23 by steve_the_composer
Not sure if this applies, but for each pattern I created I used to copy it to >at least< one adjacent pattern. That way if I messed up a pattern horribly, I could just overwrite it with one of the saved copies. --- In xl7@yahoogroups.com, "dutchbeats" <dutchbeats@...> wrote: > > a shortcut for restoring a pattern is to instead skip to an adjacent pattern, press record, then skip back to your pattern and it will be restored > > > > > --- In xl7@yahoogroups.com, Bruno <brunorc@> wrote: > > > > Yes, you did. > > > > Actually, pattern editing is a two-phase commit, so you can save your > > pattern, transpose some stuff, and if you don't like it - restore the > > pattern to the saved version, or save it. A bit of hassle, but still with > > the possibility to revert bad edit. > > > > HTH, > > > > Bruno > > > > > > 2013/3/22 stefan <nyatollah@> > > > > > Thanks, Bruno. I know about transposing, but in that case I actually have > > > to commit first in order to hear the kick in its context, for example. What > > > I'm wondering is if there's a way to sort of scroll thru midi notes > > > assigned to different kick drums for example, listen to the pattern of the > > > kick drum, in the context of the track and THEN commit. I'm not sure if I > > > made myself clear... > > > > > > SB > > > > > > --- In xl7@yahoogroups.com, Bruno <brunorc@> wrote: > > > > > > > > You can transpose contents of selected tracks in a pattern, also > > > specifying > > > > the range (so only certain notes would get transposed). > > > > > > > > XL-7 manual, Rev. G, page 86. > > > > > > > > Bruno > > > > > > > > > > > > 2013/3/22 stefan <nyatollah@> > > > > > > > > > Hello everybody! > > > > > I like to sketch out my tracks on the XL-7 and then sequence my sampler > > > > > (Emu Esynth) with the XL-7. I got my samples organized in 128s, one > > > sample > > > > > on each note. So I'm wondering if there's an easy way to browse thru my > > > > > samples by changing the midi notes of a track (especially individual > > > drum > > > > > tracks). > > > > > > > > > > Any feedback will be highly appreciated! :-) > > > > > > > > > > SB > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------ > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------ > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > >
I am not sure I understand your workflow, but that may be me (not your explanation). Here's what I think hear you saying: You record a pattern and then you want to play the pattern back, changing the midi note of an instrument >>already recorded<< so you can year how different external samples sound in the context of the track. If so, here's one method you could try: In Pattern Edit Mode, go to the note editor screen, dial up the note you want to edit, then change it. T02 NOTE <-> 001.01.002 press enter to view/edit [This will place the track into the note editor] T02 NOTE <-> 001.02.001 C02 C#4 v:64 dur:00.032 Place the cursor under the <-> to scroll through the pattern. Place the cursor under the note name to scroll through the notes [external samples] you want to test in context. To go through 128 samples/midi notes, depending on the length of the track and the number of times you use that note. Perhaps you can use the TEMPORARY BAR REGION feature to isolate a section at a time. TEMPORARY BAR REGION on From:2 Thru: 2 I am not sure if there is a way you can change >>every instance<< of a note in a pattern globally, if that's what you are looking to do. Hope this helps. Steve > 2013/3/22 stefan <nyatollah@...> [snip] > What I'm wondering is if there's a way to sort of scroll thru > midi notes assigned to different kick drums for example, listen > to the pattern of the kick drum, in the context of the track and > THEN commit. [snip] 2013/3/22 stefan <nyatollah@> [snip] > So I'm wondering if there's an easy way to browse thru my > samples by changing the midi notes of a track (especially > individual drum tracks). [snip]
Typos corrected: NOT: Here's what I think hear you saying: THIS: Here's what I think I hear you saying: NOT: To go through 128 samples/midi notes, depending on the length of the track and the number of times you use that note. THIS: To go through 128 samples/midi notes, depending on the length of the track and the number of times you use that note, will probably take a while. Apologies for these and other typos. --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote: > > I am not sure I understand your workflow, but that may be me (not your explanation). Here's what I think hear you saying: > > You record a pattern and then you want to play the pattern back, changing the midi note of an instrument >>already recorded<< so you can year how different external samples sound in the context of the track. > > If so, here's one method you could try: > > In Pattern Edit Mode, go to the note editor screen, dial up the note you want to edit, then change it. > > T02 NOTE <-> 001.01.002 > press enter to view/edit > [This will place the track into the note editor] > > T02 NOTE <-> 001.02.001 > C02 C#4 v:64 dur:00.032 > > Place the cursor under the <-> to scroll through the pattern. > Place the cursor under the note name to scroll through the notes [external samples] you want to test in context. > > To go through 128 samples/midi notes, depending on the length of the track and the number of times you use that note. > > Perhaps you can use the TEMPORARY BAR REGION feature to isolate a section at a time. > > TEMPORARY BAR REGION > on From:2 Thru: 2 > > I am not sure if there is a way you can change >>every instance<< of a note in a pattern globally, if that's what you are looking to do. > > Hope this helps. > > Steve > > > > 2013/3/22 stefan <nyatollah@> > > [snip] > > > What I'm wondering is if there's a way to sort of scroll thru > > midi notes assigned to different kick drums for example, listen > > to the pattern of the kick drum, in the context of the track and > > THEN commit. > > [snip] > > 2013/3/22 stefan <nyatollah@> > > [snip] > > > So I'm wondering if there's an easy way to browse thru my > > samples by changing the midi notes of a track (especially > > individual drum tracks). > > [snip] >
2013-03-25 by stefan
Thanks Steve, Bruno and Dutch for your help. I'll try out Steve's method. Looks like it could work. I'll report back asap. --- In xl7@...m, "steve_the_composer" <smw-mail@...> wrote: > > Typos corrected: > > NOT: Here's what I think hear you saying: > THIS: Here's what I think I hear you saying: > > NOT: To go through 128 samples/midi notes, depending on the length of the track and the number of times you use that note. > THIS: To go through 128 samples/midi notes, depending on the length of the track and the number of times you use that note, will probably take a while. > > Apologies for these and other typos. > > --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote: > > > > I am not sure I understand your workflow, but that may be me (not your explanation). Here's what I think hear you saying: > > > > You record a pattern and then you want to play the pattern back, changing the midi note of an instrument >>already recorded<< so you can year how different external samples sound in the context of the track. > > > > If so, here's one method you could try: > > > > In Pattern Edit Mode, go to the note editor screen, dial up the note you want to edit, then change it. > > > > T02 NOTE <-> 001.01.002 > > press enter to view/edit > > [This will place the track into the note editor] > > > > T02 NOTE <-> 001.02.001 > > C02 C#4 v:64 dur:00.032 > > > > Place the cursor under the <-> to scroll through the pattern. > > Place the cursor under the note name to scroll through the notes [external samples] you want to test in context. > > > > To go through 128 samples/midi notes, depending on the length of the track and the number of times you use that note. > > > > Perhaps you can use the TEMPORARY BAR REGION feature to isolate a section at a time. > > > > TEMPORARY BAR REGION > > on From:2 Thru: 2 > > > > I am not sure if there is a way you can change >>every instance<< of a note in a pattern globally, if that's what you are looking to do. > > > > Hope this helps. > > > > Steve > > > > > > > 2013/3/22 stefan <nyatollah@> > > > > [snip] > > > > > What I'm wondering is if there's a way to sort of scroll thru > > > midi notes assigned to different kick drums for example, listen > > > to the pattern of the kick drum, in the context of the track and > > > THEN commit. > > > > [snip] > > > > 2013/3/22 stefan <nyatollah@> > > > > [snip] > > > > > So I'm wondering if there's an easy way to browse thru my > > > samples by changing the midi notes of a track (especially > > > individual drum tracks). > > > > [snip] > > >
