Archive for xl7.
Re: [xl7] Menu lag?
Re: [xl7] Menu lag?
2013-03-18 by Bruno
Hi Jordan,
2013/3/18 jordan.sabie <jordan.sabie@...>
> I just got my mp-7 and have been using it with some other synths and have encountered some serious lag and hiccups while scrolling through the menu.
Most likely it's the curse of Command Station - jumping data dial. Kontakt cleaning spray should help (search the archive for "data dial").
> I am on os 1.7 .
I think it's worth upgrading to 2.0.
> Also can anyone tell me how to mute an internal sound so it just transmits the midi.
You can do this per pattern, check "Patern Edit Menu -> Channel Assign", set it to "Internal" (page 96 in manual, revision G).
Bruno
Re: [xl7] Menu lag?
2013-03-18 by Matt
I think u mean external bruno. Also go into midi menu and turn midi for that channel off.
On Mar 18, 2013 7:48 AM, "Bruno" <brunorc@...> wrote:
> Hi Jordan,
> > I am on os 1.7 .
> Bruno
Re: [xl7] Menu lag?
2013-03-18 by Bruno
2013/3/18 Matt <somatt@...>
I definitely do, thanks for spotting!
Not sure if it won't just turn off the specific channel for incoming MIDI  messages, but not the internal ones. Never tried it, but if it works that way, it's FAR better than pattern level settings and you are my hero, Matt.
Bruno
Re: [xl7] Menu lag?
2013-03-18 by Matt
If u only turn pattern to ext u will still trigger internal with pads if pads are set to send midi.
> Bruno
