Viewing edited parameters on LCD?
2013-02-15 by malikm
Archive for xl7.
Hi, I've just been wondering. Other synths allow you to view parameters that you're editing on the LCD just by twisting a knob, to control filter cutoff, for example. Is there a way to put the CS in this mode? Thanks Malik
2013-02-15 by D F Tweedie
2013-02-15 by Malik Martin
Thanks for the reply
That’s what I usually do to learn the default values of a patch, but I’d like to be able to see what I’m editing, sometimes I can’t tell just by listening. It almost makes me want to go Toni’s route and start working on a MIDI monitoring program that will tell you what you’re editing in the CS.
From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf Of D F Tweedie
Sent: Friday, February 15, 2013 12:57 PM
Subject: Re: [xl7] Viewing edited parameters on LCD?
I'm not sure about this ... but I know most other synths don't provide as many 'hard wired' controls as the 16 knobs repurposed by the 4 switch button for 64 functions with a ''reset' LED light for each parameter.
To make them really useful you have to memorize the basic 16 patch cord controls from the labels in the matrix on the CS ... and also learn to reset them to the original value where the LED light goes off. Then, for an example, you can know if you are increasing or decreasing the filter attack (or other parameter) from that set in the preset.
What I do is twist the encoder knob to bring the LED light on and then twist again until I see where it goes off ... which is now back at the original value setting. Once I 'eyeball' where the encoder is pointing at original value, I can now quickly increase or decrease the value to find what I'm looking for. IF I get lost, I just reset the patch.
The good news is that the functions are pretty much identical across all patches ... with the exception of the particular FX settings. But those too, although different from patch to patch, remain controlled by the same knobs for all patches.
It is taking me 20 times longer to explain this than it takes to do it! The explanation is complicated, but doing it is a breeze.
I do wish it worked as you asked and is someone knows better, I'm all ears.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Friday, February 15, 2013 9:19 AM
Subject: [xl7] Viewing edited parameters on LCD?
Malik
2013-02-15 by Fred Smith
2013-02-16 by Malik Martin
As much as I’ve heard about Prodatum, I’ve never tried it. I gave it my MIDI ports and it autodetected my CS and its ROMS!! I’m Impressed. I haven’t had time to figure out how it reads data from my CS but if it can tell the me patches and the params(not just the midi channel and CC) then I’m in business!!
Thanks!
Sent: Friday, February 15, 2013 4:47 PM
You can also do this with Prodatum ... either stand alone or patched between CS and your DAW.
But that's not the same as on the unit.
DF
To: "xl7@yahoogroups.com" <xl7@yahoogroups.com>
Sent: Friday, February 15, 2013 12:26 PM
Hullo, by hooking up the command station to Abelton Live you can see these values. You can record movements of controllers even!
Sent: Saturday, 16 February 2013 8:08 AM
Subject: RE: [xl7] Viewing edited parameters on LCD?
DF
Malik
2013-02-16 by Bruno
