Archive for xl7.
Starting pattern/song playback by =any= key on external keybd - possible?
2013-02-05 by vdoulepov
Hi there,
I'm looking for something "Casio-CTK-style" - a synchro-start, if you don't mind. I can definitely send a MIDI "Start/Play" from the keyboard controller, but that's not what is actually wanted.
So: is it possible to trigger pattern/song playback upon receiving the first note (first MIDI event maybe) from an external MIDI controller/keyboard?
I know a similar trick is available for recording (count-in to zero and CS waits for the first incoming event to start recording...).
Re: Starting pattern/song playback by =any= key on external keybd - possible?
2013-02-06 by steve_the_composer
Unfortunately, I don't think you can do what you want. As you know its there for recording, but not playback.
Other ways to start the clock/sequencer include foot pedal and midi start byte (which you don't want).
If its really important to your performance style, you could build a small microprocessor thing that sends the start clock/sequencer byte when a note event is received.
Steve
--- In xl7@yahoogroups.com, "vdoulepov"  wrote:
> Hi there,
Re: [xl7] Starting pattern/song playback by =any= key on external keybd - possible?
2013-02-06 by Bruno
I know it's not *exactly* what you want, but you can use a footswitch for it - XL-7 has two FS inputs and they can be programmed to work as Start/Stop buttons (amongst others possibilities).
Bruno
2013/2/5 vdoulepov <vic.doulepov@...>
Hi there,
I'm looking for something ";Casio-CTK-style" - a synchro-start, if you don't mind. I can definitely send a MIDI "Start/Play" from the keyboard controller, but that's not what is actually wanted.
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/xl7/join
    (Yahoo! ID required)
    xl7-digest@yahoogroups.com
    xl7-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
