Archive for xl7.
P1000 / P2000 / P2500 / Command Station - Hardware Differences?
2013-01-13 by K2500X
There seems to be a lot of random information out there on the hardware differences between all the lines of Proteus gear. Like the 2500 had better converters (24bit) and faster CPU speed/midi response than the 2000 line. Any truth to that? Are the command stations and 2500 exactly the same except for the pads? Did the P2000 hardware change over time? I.e. did the Vintage Pro have upgraded converters/CPU over the original P2000? The keyboards were also interesting in that they had the Proteus 1000 level specs, but accepted 4 ROM boards instead of only 2 like the rest of the 1000 line.
Re: [xl7] P1000 / P2000 / P2500 / Command Station - Hardware Differences?
2013-01-13 by D F Tweedie
I'd add that the way I look at it, the only difference between the 1k and 2k is the extra ROM slots, SP/DIF and additional sub outs on the 2k. Architecturally they are the same. I believe they all conform to the 12 'real time controller' preset design.
Yes, the CS and 2.5K are identical except for the pads and physical design of the chassis. They do have improved audio and a few other upgrades.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
To: "xl7@yahoogroups.com"
Sent: Sunday, January 13, 2013 11:53 AM
Subject: Re: [xl7] P1000 / P2000 / P2500 / Command Station - Hardware Differences?
If you have never seen it, this is useful:
http://www.creative.com/emu/company/history/timeline/
DF
Sent: Sunday, January 13, 2013 10:00 AM
Subject: [xl7] P1000 / P2000 / P2500 / Command Station - Hardware Differences?
Re: P1000 / P2000 / P2500 / Command Station - Hardware Differences?
2013-01-14 by K2500X
Appreciate the link to E-MU history. I guess what I'm getting at is, are there really any audible or other performance differences to the various models that people have actually noticed?
> DF
>  From: D F Tweedie
> DF
>  From: K2500X
> To: xl7@yahoogroups.com
2013-01-17 by steve_the_composer
I don't know if this was mentioned, but with the Command Stations and P2500 you get a built-in sequencer with 16 buttons that double as track enables/mutes and triggers (among other features), and 16 knobs that rotate through quick edit, program, volume, and pan.  To some, those are well used performance features.
I haven't seen anyone do any kind of measurable analysis of the audio output of the numerous variations (p2k, orbit, xl-1, etc.), though I have seen people say that a specific model had more punch or bass or whatever than another model.
Not sure this helps you make a decision, but its my 2 cents worth.
Steve
> > DF
> >  From: D F Tweedie
> > DF
> >  From: K2500X
