Archive for xl7.
composer rom in command station - missing patchcords ?
2013-01-10 by jezfez
the patch cords for my composer rom are not mapped correctly
the amp decay and amp release knobs are patched to lfo2 amt and lfo2 rate
i assume this is because the composer rom is from the proteus 2000 which only has 12 knobs?
anyone else notice this with their composer rom ?
thanks
Re: [xl7] composer rom in command station - missing patchcords ?
2013-01-10 by D F Tweedie
Hmmm ... interesting.
I know that the default 'real time controller' midi CC assignments are different in the 2k and 2.5k units. In other words, the first 12 of the 2k 12 and the 2.5k 16 are not the same.
However, I always thought you could simply change that CC assignment on the unit as you wished ... although that would obviously change the output if you were using the units knobs to send midi elsewhere.
Therefore I assumed a ROM from a 2k unit placed in a 2.5k unit would respond as the A through L controllers regardless of what CC they were assigned. Also, when I used the knobs on the Proteus 2500 to control the ROM from Planet Earth, a 2k 12 knob unit, everything seems to work as expected. I don't know why this would be any different for Composer, although mine is in a P2k.
I just got done last night remapping a desk with fixed midi outputs for both 2k and 2.5k using PIZ MIDI 'midi16CCrouter.'
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Wednesday, January 9, 2013 5:27 PM
Subject: [xl7] composer rom in command station - missing patchcords ?
thanks
Re: composer rom in command station - missing patchcords ?
yes it is easy to remap the knobs and save as a user preset, just a bit annoying when browsing presets that might benefit from some release
it is odd, surely they could have used the same cc#s for the lfo knobs
maybe my composer rom is corrupt
i would love to hear from anyone with a composer rom in their cs - do your lfo2 knobs work or are they moved to sustain/release ?
thanks!
Re: [xl7] Re: composer rom in command station - missing patchcords ?
Just to clarify, I don't believe the knobs reflect any specific CC, such as the common use of CC 74 for filter cutoff. Filter cutoff is a function of the patch cord. The CC message just adjusts the amount of the patch cord ... which secondarily affects whatever it is attached to in the programming.
I know that in my Virtuoso manual it states that the label functions on the unit are 'general,' and any specific preset may not have that 'labeled' function assigned to the specific real time controllers for that preset.
I'm not feeling generous enough to unrack everything to pull my composer from the P2k and slap it in the CS. But if you identify the preset, I'd be happy to report the effects of the controllers with the ROM in the original unit.
DF
Sent: Wednesday, January 9, 2013 7:27 PM
Subject: [xl7] Re: composer rom in command station - missing patchcords ?
thanks!
2013-01-10 by steve_the_composer
I don't have time for a lengthy reply here, but as others have suggested,  there are a few different things:
1. The CC values that are set in master/global for MidiA --> MidiP.
2. The patchcords that assign synth engine functions to MidiA --> MidiP [and therefore the CCs they are assigned].
3. The labels for the knobs that are printed on the unit itself.
As pointed out, the 12-controller ROMs and the 16-controller ROMS have different function assignments in the patchcords. Also, different ROMs have different conventions for making use of patchcord and functions. Therefore, the names on the panel do not apply to all ROMs.  Is this what you are talking about?
Sorry for the brevity here. If this doesn't help, I will have more time later.
Steve
> thanks
2013-01-11 by jezfez
i understand, thanks for your help
better engineering could have had these knobs mapped to their correct labels and skipping the others
jamming away while trying to remember what preset is from what rom to know which knob to turn is a bit of a drag
do you know what roms support the cs 16 knobs by default ?
thanks guys!
2013-01-12 by D F Tweedie
Steve wrote: "I started a table and tried to get members here to contribute basic info about each ROM, including whether each was a 12-controller ROM or a 16-controller ROM. Not a whole lot of people contributed. The table as I put it together in May is in a folder called TEMP in the files section. Its called ROMS pdf. Its probably about 7% complete. I'd be happy to fill it in if people here want to supply the information about each ROM they have that's not already in the table."
There is a possibly incomplete ... though I doubt it, but simple answer. Any ROM from a CS, the P2.5K or Proteus Keys has 16 patch cords. Any ROM from a P2K unit, the bespoke model with Composer, Virtuoso, Planet Earth, etc., has 12 patch cords.
How do I know? Look at the hardware!
DF
Sent: Friday, January 11, 2013 2:53 PM
See below.
My understanding is that they ARE mapped to the correct label for each ROM that is native to a specific box. In order words, the XL-7 labels match the XL-7 ROM presets, the XL-1 labels, match the XLEAD ROM presets, etc.
The problem (if you want to think of it as a problem as opposed to an opportunity to really delve into the architecture of the gear)comes in when people put non-native ROMS in their boxes, such as a P2K Composer ROM in a Command Station (or supplemental ROMS that could be purchased separately).
Unfortunately, the boxes were so well designed that many people don't go beyond the default settings and will just tweak presets as opposed to design their own from scratch. I found it was a fun challenge to zero out all of the patch cords and build a set of presets from scratch.
Yes, there is a lot to learn, and if you accept the challenge you will surely will be able to do things beyond what you first imagined. I would encourage such exploration. You really get to know what's what.
I agree for starters, it is nice that MidiA is Filter Cutoff, MidiB is Resonance, etc. Even after all these years, I don't change a number of these default assignments. Its just a very handy convenience.
Oh, by the way you might find that even with the factory designed presets any particular knob will control different sound shaping parameters via patchcords on different layers in the same preset. I would encourage you to dissect some presets to see what the sound designers did to get the various effects. That way you will have insights into making the box do what you want.
I use pen and paper, sometimes an index card. Also, if you tweak (or design) presets or just reorganize the factory presets you like, you can use some naming conventions to make it easier to find presets. (I will see if I can find some posts that describe some of the naming convents I use--such as 001: and 002: as prefixes for families of repated presets, using CaPs, etc.
Steve
I'd add, that the Ensoniq Halo appears to be the only keyboard model with only 12 patch cords (4 knobs with three switches), so that ROM is presumably for 12 patch cords only.
DF
See below.
Steve
2013-01-13 by steve_the_composer
Footnote: If you are familiar with the "syxer" program I have mentioned, one advanced (in the way future) idea is what I call the "parametizer." I have never coded it, buts have some developmental plans. One of the features would be the ability to store and recall preferred parameters, such as patchcord sets. So if someone designed some 12-controller or 16-controller setups they liked, they could apply them as a template of user parameters to build presets.
However, in order to build the software, I would need detailed info about all the ROMs and I just do not have the time to mine and map each of the ROMS.
Just like syxer can change ROM IDs in a bank of presets, it would be cool to swap in a template of preferred patchcords. I suppose it would be possible to extrude a set of patchcords from one designated preset and apply that to a whole bank of user presets. There is no guaranteeing what it would sound like, though, just like switching ROM IDs.
1. Extrude one set of layer level patchcords (4 layers) from a known 16-controller preset.
2. Apply it to a bank of 12-controller presets.
3. Listen to the bank for any useful results.
4. Tweak any promising presets and save.
Could probably do something (no range checking or anything) in syxer.
Of course, if anyone else wants to code this, I'd be happy to contribute what I could.
Steve
By the way, I don't know, but I assume all the ROMs that were not specifically included with gear have presets on board that were designed for the least common denominator--12 controllers. I only have the Protozoa, and that's for 12 controllers (Still more than the original P/1/2/3s.
> DF
>  From: steve_the_composer
> To: xl7@yahoogroups.com
> See below.
> Steve
