Archive for xl7.
Two track latency???
2013-01-06 by nikitsanpsix
I have psoted some time ago about routing mp7 to external compressor for parallel NY style compression... I have my answer, and thanks to all guys who helps me .
And now I have another trouble with parralel compression...
I have properly conected and routed my outbord compressor to sub 1 and all is working, but there are small differences above few milliseconds with clean and processed signal. It`s sounds not good (flickering in start). To exclude my compressor latency i try simply make two idetical tracks with one kick sound preset (without any fx at all), and i have this latency again.
Any body can try this, two identical tracks sounds with latency!!!!!
why? and how to correct this issue????
Re: Two track latency???
2013-01-09 by nikitsanpsix
nobody?
Re: [xl7] Re: Two track latency???
2013-01-09 by Alwyn
So you are seeing some timing difference between the Sub Output and the Main Output?
On 9 January 2013 16:25, nikitsanpsix <nikitsan@...> wrote:
nobody?
No I have  it even if ie track1 - kick sample (main out), track2 - same kick sample (main out). In result i have some phasing, and flicking sound on output.
when i route track2 on sub out 1 for compressing and return it to my MP7 there is same phasing issue and flick on begin of sample.
> Main Output?
> On 9 January 2013 16:25, nikitsanpsix  wrote:
> > nobody?
> > who helps me .
> > again.
2013-01-09 by steve_the_composer
Hmmmm. now that you mention phasing, I am remembering something I stumbled onto a few years ago. I turns off all FX and anything that would cause minute delays or pitch shifts, chorus, flange, etc. I repeatedly hit a note and found that the timbre of the same note played one after another was different, like there was an unexplained phase differential. I don't remember much more of my experiments or if I ever tracked the cause down. I want to say that with each keypress, depending on what the processor was doing, there was a miniscule phase difference.
Not sure if this is what you are talking about; not sure how much of this I am remembering correctly.  I will try to search the archives.
Steve
> > Main Output?
> > > nobody?
> > > who helps me .
> > > again.
Here's the post I was remembering.  It was in reply to another post.  Maybe the discussion applies to your situation.
http://launch.groups.yahoo.com/group/xl7/message/13787
Steve
PS: I can't believe I found the post so quickly!!!!
> Steve
> > > Main Output?
> > > > nobody?
> > > > who helps me .
> > > > again.
2013-01-10 by nikitsanpsix
Yes!!! exactly what I`m talking about! Have you any solution for this?
> Steve
> > > Main Output?
> > > > nobody?
> > > > who helps me .
> > > > again.
2013-01-10 by johnnie5917
Oh dear.  I had dusted off my XL7 and was starting to have quite a lot of fun thinking I would go back to using a hardware sequencer and do a couple of tracks with it.  I had been reading about how the timing on these things was to die for compared to software sequencers etc.
Back to Ableton, Logic and Reason I suppose.
> > Steve
> > > > Main Output?
> > > > > nobody?
> > > > > who helps me .
> > > > > again.
2013-01-10 by Alwyn
Do you get the same delay using different samples/patches?
> > Steve
> > > > Main Output?
> > > > > nobody?
> > > > > who helps me .
> > > > > again.
I hear it mainly on kick samples.
> > > > Steve
> > sound on output.
> > and the
> > > > > > Main Output?
> > > > > > > nobody?
> > compressor for
> > all guys
> > > > > > > who helps me .
> > sub 1 and
> > milliseconds with
> > start). To
> > tracks with
> > latency
> > > > > > > again.
> > latency!!!!!
Exactly what I was trying to do. Sync to a kick drum in ableton.
I was then going to try to play some of the riffs from the XL7 with other instruments.
Was a good idea to start off with - like so many!
> > > > > Steve
> > > sound on output.
> > > and the
> > > > > > > Main Output?
> > > > > > > > nobody?
> > > compressor for
> > > all guys
> > > > > > > > who helps me .
> > > sub 1 and
> > > milliseconds with
> > > start). To
> > > tracks with
> > > latency
> > > > > > > > again.
> > > latency!!!!!
2013-01-10 by steve_the_composer
I haven't played with it since participating in that thread, but I am guessing that I was close when suggesting that the seemingly random phase shifting contributes to the E-Mu's "phatt" sound (what the original post called a flange-like sound). In the thread I believe someone suggested changing pan, detune, etc. to get rid of that effect. There may be other ideas. Not sure when I will have time to reconstruct and play around with it.
Since the effect was related to the same sound being generated by multiple layers, perhaps if the preset you are using has the same (or similar) sound on different layers, turn off all but one layer to see if it goes away. If so, you can redesign the preset accordingly.
Hope this helps.
Steve
O! it`s a good idea with layers. Maybe somebody knows, can I route different layers to different outputs?
> Hope this helps.
> Steve
2013-01-11 by steve_the_composer
I am not in front of my gear, it seems that the Mix Output operates on layers. Assign layers to different sends->sub outs. However, only main has FXA/FXB.
L1 MIX OUTPUT
Send2->main
2013-01-11 by Bruno
BTW: isn't it the same effect like if you were playing the same MIDI notes on the same patches on two different channels? Or sending doubled notes from the external sequencer (happened to me few times and it's f...ing annoying).
Bruno
2013/1/11 steve_the_composer <smw-mail@...>
L1 MIX OUTPUT
Send2->main
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/xl7/join
    (Yahoo! ID required)
    xl7-digest@yahoogroups.com
    xl7-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
2013-01-11 by nikitsanpsix
this is exactly what we are discussing here.
> annoying).
> Bruno
> > FXA/FXB.
> > L1 MIX OUTPUT
> > Send2->main
> > Yahoo! Groups Links
but I have not tried an external sequencer.
> annoying).
> Bruno
> > FXA/FXB.
> > L1 MIX OUTPUT
> > Send2->main
> > Yahoo! Groups Links
2013-01-11 by Bruno
The usage of external sequencer doesn't really matter. If you trigger the same sample twice in the same time, you will always experience chorus effect. This is also a reason for E-mu "cheap"; implementation of chorus effect on the polyphony level.
As strange that it can seem, if you want to have more powerful sound (instead of chorus), maybe just fight fire with fire - use the same sample, but experiment with Sound Start/Delay parameters for one layer?
2013/1/11 nikitsanpsix <nikitsan@...>
> annoying).
> Bruno
> > FXA/FXB.
> > L1 MIX OUTPUT
> > Send2->main
> > Yahoo! Groups Links
Yahoo! Groups Links
2014-07-16 by smw-mail@...
I seem to remember doing a test many years ago. If I recall correctly, I had the same ROM instrument on two layers, no effects or anything, short attack, etc. I triggered a single note and the two layers did not always hit at the same time. There seemed to be some nanoseconds of variation. I will see if I wrote that up.
