Re: [xl7] Song Recording with Patterns
2012-12-03 by D F Tweedie
How funny! I just posted a similar question about beats!
There may be better ways, but what I did was simply midi record the pattern into my DAW sequencer, setting up 16 tracks fed from my PX7, each set to a different midi channel.
I did a preroll on record and then punched play. All the track then recorded out. You do have to go to the midi menu and select 'transmit' under 'Keyboard MIDI Output.'� You can also do that, select 'transmit' in the midi menu for the controller.
While your pattern/ songs are playing you can then turn tracks off and on 'on the fly.' You midi record your whole performance and edit to taste in your DAW. Now your turn your midi tracks around and instead of them getting MIDI input from the unit, you change the unit target to midi output from your
tracks.
You are now ready to render the midi to audio, if that's what your goal is.
Ideally, you 'track' and record each midi track separately to audio ... so you can do a full on audio mix down.
Also, either while recording the audio ... or better, with recording midi ... you can also have a go at the controllers on a track by track basis for modulation fun. If you record the midi output while tweaking, you can then edit it in midi to get real precise with the modulations.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Sunday, December 2, 2012 10:25 PM
Subject: [xl7] Song Recording with Patterns
Hi, everyone!
First off, thanks to those of you who chimed in when I was poised to sell my MP-7. I did keep it, and finally have had time to sit down with the manual and tinker, in general. Happy accidents have led to a understanding of how to do most of the basic things I really wanted to do.
I have a pattern that's pretty long and varied. I'm finding that realtime recording is meant only for the pads, and step recording as I currently understand it is more ideal for short patterns or ones in which any changes to the pattern occur on downbeat one of subsequent patterns. I'm prepared to either bounce all 16 tracks into a DAW and manually build the song, but wanted to check with you first: Is there anyway that I might be missing, to record the muting and unmuting of tracks on the fly? Bringing in parts, say at measure two, instead of having to wait until the next bar begins, or to be able to capture a "performance" in which I'm rhythmically muting a track for a stutter/slice effect?
It's not the end of the world if it's not possible, but I wanted to make sure before I try something else. Thanks very much for all the great info here - I'm love my Command Station. I look forward to getting more ROMs, but so far, I'm able to get a lot of great stuff by manipulating the presets in the MP-7.
- J
- J
